Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-07-2005, 01:07 AM
strategy strategy is offline
'98 Explorer Bucks on Turns
Every so often, when I make a turn, the front wheel on the side to which I am turning seems to stick and buck, almost as if I am in 4WD and trying to make a tight turn, but much worse.
It seems to go away if I apply and take off the parking brake, but I'm not sure if that is actually doing it or is just that it happens to stop at the same time I decide to try.
Odometer is at 140,000.
Any thoughts? Thanks much!
Old 06-09-2005, 09:41 PM
B33p3r B33p3r is offline
Stupid question...but are all your wheels the same size? And do you actually know it's not in 4 wheel?
Old 06-11-2005, 10:29 AM
chr97 chr97 is offline
Re: '98 Explorer Bucks on Turns
Maker sure you tires are also not to fat and you have clearance when you are turning, Check to see if you have unusual wear on the inside and if you have a shinny polished spot on your tortion bar.
Old 06-26-2005, 12:14 AM
Turns out it became undriveable. Needed a mere $2,000 in front-end work. Can't complain. I never did anything to the f/e and it has 140k on it. Thanks to all.
