Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 06-06-2005, 11:19 PM
jeremykjones jeremykjones is offline
Door Wiring problem
Hey,
Searched this and got nothing, sorry if i over looked something. GM is out of my area, this is a common question but i just want ot make sure that I know what i'm getting myself into.
have a 1998 Sonoma, power everything blah blah.. The wiring is off in the door someplace. When you shut the truck off it normally shuts off, in this particualar truck it no longer does that. There was some work done on the power window for the drivers side. Just curious if anyone can tell me how easy this is going to be to fix. It acts as the "hinge touch point" isn't reading, i'm guessing it is just a crossed wire, but not sure. If anyone has a pic or a diagram that would be great. Any advise would help me. Thanks
Jones
Old 06-16-2005, 07:31 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Door Wiring problem
check the harness inside, probably has a ripped wire.
Old 06-16-2005, 11:50 AM
Re: Re: Door Wiring problem
which harness?
Thanks for all ur help I am desperate at this point.. lol
Jones
Old 06-16-2005, 02:28 PM
rlith's Avatar
door harness, main bundle coming from the boot between the door and the body
Old 06-16-2005, 04:59 PM
thanks i'll check on it!
Old 06-16-2005, 09:00 PM
drdd's Avatar
drdd drdd is offline
not sure i understand your question or even the symptoms ... however ...
is your door sagging? Is the "door is ajar sound" sounding? Is the dome light on or flickering when it shouldn't be? check the door hinge pins for deterioration.
Old 06-17-2005, 01:37 AM
yea it is on when it shouldn't be,
When you cut off the engine, the radio use to keep playing and than cut off when one of the doors opens, this still works with the passengers side door but not the drivers door. Everything in the interior stays on... i have no clue what is going on...??
