Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-06-2005, 10:06 PM
nova1313's Avatar
nova1313 nova1313 is offline
idle dropping at start.
Okay so my car was fine when I first got it. About a month later it started to have this problem where when started the RPM's would drop to 300-400rpm for a few second then go back up and all was well..
About 2 weeks ago it started to actually stall when it did that. So I went and i replaced the air filter, and fuel filter (this was crap, black gas poured out).. So I went and ran the tank through filled up and I'm back to the low idel when starting the car again.. At least it doesn't stall but what should I try next to fix this?
Injectors? New plugs?
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 06-23-2005, 10:00 AM
fredie_gie fredie_gie is offline
Send a message via Yahoo to fredie_gie
Re: idle dropping at start.
i would also like to know what you can do to fix this because my 94 eclipse is having very similar problems.
