Old 06-06-2005, 09:48 PM
Learningful Learningful is offline
Unhappy PG7 troubles
I have a DOHC ZC with a PG7. It's acting up and the LCD's flashing 7. What's the problem? Any help concerning the troubleshoots would help. Thanks,
PS. If anyone knows where I can find a list with what all the different flash codes mean, it would be greatly appreciated too thanks again!!
Old 06-06-2005, 11:01 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: PG7 troubles
its in the FAQ at the top of this forum. just search a little and you will find it
code 7 - throttle angle.
thats a throttle position sensor code. check the connection on your TPS, and also check to see that its adjusted properly.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
