Old 06-06-2005, 07:53 PM
bulldogue bulldogue is offline
Intermitent A/C
I have an intermitent problem with my A/C and I'd like to know if any of you could direct me to the source. See when I first start the A/C it will cool for about 20-25 minutes then it shuts down. After stopping the truck for a half hour the A/C will start again will not last as long as the first time 1-2 minutes. Could this be a relay problem of some kind?
Mike
2000 Silverado 4X4
6.5 Turbo diesel
Old 06-06-2005, 10:30 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
what shuts down the compressor or the switch panel? could it be freezing up? could be a bad compressor?
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 06-07-2005, 02:06 AM
2000CAYukon 2000CAYukon is offline
Re: Intermitent A/C
When it shuts down, pull over and take a look at the accumulator (near the passenger side firewall). If it is iced up, then the evaporator is iced up restricting air flow thru it.
If it is icing up, then the pressure cycling switch is bad or you have too much freon in the system.
//2000CAYukon
Old 06-07-2005, 06:57 AM
pies pies is offline
Re: Intermitent A/C
when the air conditioning is running , check on the passenger side of the vehicle and see if there is water dripping out. if there is not , then the water drain is plugged. this will cause the air box to fill up with water and it will freeze and block the air flow. just unplug the water drain. a small screw driver will do this.
Old 06-07-2005, 04:21 PM
I will be checking this out tomorrow. The truck is getting it's fifht wheel installed. Also called the dealer today and I was directed towards the pressure cycling switch. They say's it's a common problem.
Thanks all.
Mike
Old 06-07-2005, 04:26 PM
Re: Intermitent A/C
Thanks all.
Mike
Very common and that is what happened on my 90 K1500. The good news is they can be replaced without removing the freon.
//2000CAYukon
Old 06-09-2005, 04:49 AM
Thank you for your reply 2000CAYUKON....You gave me the answer to my next questions I had this morning. I opened the thread and there was my answer about removing it without loosing freon. What a timing!
Mike
Old 06-28-2005, 06:50 AM
redneck45 redneck45 is offline
Re: Intermitent A/C
I just had my '99 stop blowing cold for about 5 min, then started blowing cold again for a few min, then back to warm again, then finally back to cold and continued to work for a 5 hr drive in 95 degree heat! Weird! Only time it ever did it. No icing up and the drain was draining!
