Old 06-06-2005, 05:09 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
quick question
I had my car broken into few months ago and the easiest take was my apexi vafc.. mounted on steering console. but i got a new 1 of course and i dont wanna mount it in a location that makes it so easy to be swiped! so i was curious to know how hard it is to take off the grey piece of trim on top of the dash.. that meets with the window.. i wanna install all my apexi systems there vafc-boost
Old 06-06-2005, 10:58 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: quick question
you mean that light grey vinyl piece? thats part of the dash, you have to remove the whole dash to get it. and even then, its glued to the lower dash part with some serious glue
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-07-2005, 11:40 AM
Sparsky Sparsky is offline
Re: quick question
You have to remember also... criminals don't really care about breaking stuff in order to get what they want.
My truck was broken into 2 times for the stereo. 1st was a cheap sony hung by factory mounting, they got it out pretty easy. 2nd was a 300 dollar reciever. I bolted that bitch in with metal straps etc. Well they ended up f'in up my whole dash getting it out. Unlike the 1st time when the stereo popped out easy and they just left.
http://www.cardomain.com/memberpage/765867
Old 06-07-2005, 05:50 PM
americansk8er85 americansk8er85 is offline
Re: Re: quick question
People who steel things suck, esp. when we work hard for this crap.
Old 06-07-2005, 07:52 PM
Re: Re: Re: quick question
I couldn't agree more.
Old 06-07-2005, 08:48 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: quick question
put it in the glove compartment when you get out or custom mount it to your visor
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-07-2005, 10:23 PM
Hey guys thanks for the replies. sun visor.. thats a idea. i pretty much got the whole interior gutted out including the glove box but i could always reinstall it. i wanna find a way to mount these guages and be able to take them out and install them in seconds on a daily basis. I got another question tho how long does it take to take the dash off? after reading the right way of painting interior parts from incucivic's post on interior painting.. i wanna paint that grey trim piece i mentioned about b4. thanks again
Old 06-08-2005, 11:36 AM
EF You's Avatar
EF Life Giver
Re: quick question
theres a bolt on each side of the dash, if you take off the vents that are in the area between the door and the dash. theres also a bolt in the top center of the dash, under that small rectangular plate. then if you take off the center console, theres a bolt in the center that bolts to the floor.
there might be one or two im forgetting, its been a long time since ive taken an EF dash out. but thats enough to get you started so you can wiggle the dash and find more bolts if they have any
Old 06-08-2005, 11:46 AM
thanks man. ur a big help to this forum!!!
Old 06-08-2005, 04:03 PM
EF You's Avatar
EF Life Giver
Re: quick question
no problem.
i just looked at my coworkers EF, and theres a few more bolts for the dash. if you take off the panel under the steering column, theres a bolt there, on the far left. theres also ones by the glove box, so take the glove box off too. then theres some under the gauge cluster as well.
also, when you take the center console off, unbolt the climate control, but dont unplug anything from it. then when you are taking the dash out, rotate the control and let it slip out of the dash. this is a lot easier than taking all the cables and wires off the back
Old 06-09-2005, 06:25 PM
1989CivicSi's Avatar
1989CivicSi 1989CivicSi is offline
Send a message via AIM to 1989CivicSi
just use velcro mount it on top of the dash in the middle, and when you leave the car just put it in the glove box, i did that with mine and it was awesome haha
91 Honda Crx Si Metallic Blue Pearl
90-91 B18a1
Action Stage 3 clutch
Clutchmaster 8lb aluminum flywheel
Place Racing motor mounts
Revo Short shifter
Short ram intake
2 1/4 exhaust
17in Tenzo R Shu 4's
Kumho Supra 712's (cheap tires )
Old 06-09-2005, 08:10 PM
Re: quick question
that's a pretty good idea
