Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 06-06-2005, 04:20 PM
V T E C H's Avatar
V T E C H V T E C H is offline
throttle body?
What are the advantages of having a custom throttle body, what does this do for the car, is it worth the cash? I didnt know, so i thought i would ask you guys.
thanks in advanced.
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 06-06-2005, 09:52 PM
geisi13 geisi13 is offline
Send a message via AIM to geisi13
id like to know the same, i have an aftermarket intake manifold and an obx throttlebody spacer and was thinking of getting a throttle body to go with it before i put it all on, would it be worth it? all ive heard is that if you havea bigger bore throttle body it will give you a quicker throttle response and more high end power
GEISI
DRIVE FAST AND TAKE CHANCES
Old 06-06-2005, 10:19 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: throttle body?
I personally wouldn't waste my $ on it, unless you've got a high hp setup. When you start getting into things like intake manifolds and bigger throttle bodies, you're running the risk of losing hp in most of your powerband. Like if you were looking at a dyno sheet; you may gain max hp but lose hp throughout the powerband. I'm not saying that it will happen, but it is possible.
Old 06-07-2005, 01:03 AM
V T E C H's Avatar
Re: throttle body?
Well thank you, that was very informative, but i still was wondering what exactly a bigger throttle body is doing, why is it adding, or losing in some cases, hp.
Old 06-07-2005, 09:03 AM
what about boring the stock thorttle body? im gonna be running a bigger turbo soon, would it be in my better interest to do this? because i would have more airflow
GEISI
Old 06-07-2005, 10:33 AM
95whitehb 95whitehb is offline
Send a message via AIM to 95whitehb
Re: throttle body?
it allows more air to come in faster; it can help alot, if yer setup is askin for more air .... but more times than not ppl just buy them b/c they think "they add hp" to every motor setup.... n they end up losing power
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap.
'95 CX hatch:
-JDM ITR swap ('98 spec.)
-ITB's
Old 06-08-2005, 06:12 PM
V T E C H's Avatar
Re: throttle body?
so if you had a turbo/supercharger this would be a good idea, or your car was very moded NA? other wise you are losing hp across your powerband and only gaining it at a certian point? am i getting it or am i way off?
Old 06-08-2005, 06:33 PM
CivicSpoon's Avatar
There is no Spoon
Re: throttle body?
You've got it. It shouldn't be considered a basic bolt-on. It should be for high hp FI or NA applications.
Old 06-08-2005, 08:16 PM
ok so since my car is turbo then it would help me. would i be better off boring my stick throttle body or buying an aftermarket one?
GEISI
Old 06-09-2005, 12:45 AM
sivic02's Avatar
sivic02 sivic02 is offline
Re: throttle body?
If your gonna do it do it right, Individual throttle bodies...mmmm....sexy....
Heres a way to think about it, unless youve had to upgrade your fuel delivery then you wont need to worry about the throttle body yet.
Here's to being single, seeing double, and sleeping triple
Old 06-11-2005, 01:46 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: throttle body?
I could be wrong, but there was a discussion about individual throttle bodies before, and I thought I remembered the fact being brought up that you can't use individual throttle bodies with a turbo.
Old 06-11-2005, 02:05 PM
sivic02's Avatar
Re: throttle body?
Making an airbox like some guys do for running a CAI on the ITBS it makes sense that you should be able to run a turbo on it, might be a pain in the ass but I think it could be done. I dont know for sure so I could be wrong, if someone knows for sure let us know!
Old 06-11-2005, 03:39 PM
97integrals's Avatar
97integrals 97integrals is offline
ITB can be used with FI you just have to make a plenum for the runners. There are lots of people running this kind of set-up. I know I have seen some pics on Honda-tech before I'll try to post them up here.
Old 06-11-2005, 04:40 PM
here ya go, pictures are of tony the tiger's gsr with ITB and turbo.
more info about the car and video's at this website:
http://www.geocities.com/leunghomepage/
Old 06-12-2005, 12:06 AM
sivic02's Avatar
Re: throttle body?
Thanks for clearing it up and posting the pics, and about the pics i think it is safe to say...
