Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
View Poll Results: ran out of gas need help on starting??
off 0 0%
on 0 0%
on 0 0%
on 0 0%
Voters: 0. You may not vote on this poll
Old 06-06-2005, 03:46 PM
Ctijerina Ctijerina is offline
2000 impala ran it out of gas does not start anymore??
ran car out of gas, put more gas back in and does not want to start anymore any suggestions on what to do or look for???
Old 06-07-2005, 03:04 PM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
Re: 2000 impala ran it out of gas does not start anymore??
this problem usually is because the fuel pump isnt primed.
how long are you cranking it for? it might take a while.
Old 06-12-2005, 09:40 PM
montecarlossfan montecarlossfan is offline
fuel injected should start right away see if u can hear a whine when u turn the key forward but not starting it, if not check the fuel pump fuse/relay
Old 06-22-2005, 03:47 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
First of all, it isn't good to run any of the late models out of gas. The gasoline actually helps cool the pump (it's located in the tank) and if you run the car out of gas, you risk burning up your fuel pump.
That said, there is a fuel pump reset on your car somewhere, I'm not sure where, but your owners manual should tell you. Maybe you'll luck out and be back in business by reseting it.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 06-22-2005, 04:28 PM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
I did the same thing to my impala also...i don't realize it has a gas gauge in it until the low fuel light comes on...i'm terrible for not paying attention to it. But to the point...i had the same problem with it not starting.....i finally took my finger nail and pressed on the thing that looks like the stem on a tire...i pressed on it until gas was in the fuel rail.....took a bit..but it finally started squirting everywhere....and then with a few attempts of starting it...it finally started...ran like shit for about a minute and then it was fine. But lesson was learned on my part and it's only happened once...(knock on wood).
mike
