Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 06-06-2005, 01:32 PM
boonej boonej is offline
Angry Fuel Tank Pressure Sensor
Hey has anyone ever replaced this before or even just removed a fuel tank from a bravada before. I'm trying to figure out if I can lower the tank enough to get at this sensor without having to disconnect everything or if I have to remove everything just to replace this sensor.
Old 06-07-2005, 03:00 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Fuel Tank Pressure Sensor
What year?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-07-2005, 03:01 PM
Old 06-09-2005, 07:48 AM
AF - Advisor
On my '97, all wires and fuel lines were connected to the fuel pump/fuel level assembly hanging inside the fuel tank and the fuel tank has to be removed to change anything out.
