Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 06-06-2005, 10:01 AM
cantrol cantrol is offline
Question Longevity
Does someone have an idea for how long can be run an escape before it becomes a headache?
Old 06-11-2005, 11:35 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Longevity
I have a Mazda Tribute that I bought new in Feb. of 2001 and now it has 64000 miles on it. I like power, so I have the V6-200HP engine, auto, and 4x4. It gets 16-20 mpg or so....The only complaint is small gas tank....light comes on at 13 gallons or so (about 230 miles)......
Good car but poor dealer network.
Plastic stuff will break. Had two sets of front brakes, one set of rotors and 4 tires. Front tires go....V6 car though.
3 check engine light issues (EGR related)...on warranty.
Had to repair the cruise control cable also (repaired myself with a pin).
I use synthetic oil in it. Auto trans not always smooth.
Happy with truck...good price...good looks.
Old 08-12-2005, 03:38 PM
spotovi spotovi is offline
Hi All,
I have a 2002 Escape XLT with 62 000 Km on it.
I had the front support arms and lower A arm changed on it. My tires will have to be replaced in the fall. I wonder about the motor but it seems to be ok at this time. My trans shifts into OD funny sometimes but it works for now.
Regards,
Spotovi
97 Integra, 10th Anniversary Addition.
(RS with Non-Leather GSR interior)
B18B
K&N CIA
Custom Bent SS Cat-Back w/SS Dragon Style Muffler (4.5 Inch tip).
Stock Suspension
Stock 14" wheels
Goodyear Eagle HP
Stock Brakes
Old 08-12-2005, 10:15 PM
AlohaBra's Avatar
Re: Longevity
Originally Posted by spotovi
Hi All,
Regards,
Spotovi
My trans shifts the same way..I might have the fluid changed to synthetic because of higher temp tolerance.
I don't why U had the A arm changed...????
Tires always wear out....the front suspension is a McPherson strut design and with front wheel drive...tires always get burnt up.
Motor is good....I use synthetic....10w-30 Castrol. 65K on it now.
Old 08-14-2005, 12:24 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
2003 (& technically very early 04MY) Escapes seem to be the most prone to the suspected Zircon contamination.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
