Old 06-06-2005, 09:41 AM
cknadroj's Avatar
cknadroj cknadroj is offline
Cracked Plastic Radiator Tank
Hi:
Just like my 93 K1500 did last year, my 95 Suburban's radiator has cracked vertically about 4 inches long in the middle on the front of the driver's side plastic tank behind where the upper hose comes in.
A new aftermarket 34" radiator is nearly $250. We only use the Suburban for pulling a horse trailer twice a week.
Has anyone had any luck J-B Welding or otherwise patching cracks like this?
Thanks for you opinion...
Old 06-07-2005, 02:21 AM
Tall Tall is offline
Re: Cracked Plastic Radiator Tank
Hrm, I don’t think JB weld would be a good permanent solution, if your using the engine for pulling you need the cooling system in decent shape or you will end up on the side of the road waiting for a tow truck. Honestly, their isn’t really a decent way to fix plastic parts, best thing to do would be buy a new one.
Old 06-08-2005, 07:31 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Are you talking about the plastis over-flow tank, or the radiator itself?
If you mean the radiator...buy a metal one!!!!
Old 06-08-2005, 08:53 PM
broughy84's Avatar
broughy84 broughy84 is offline
get some plumbers stick epoxy. It will fix anything. Email me and I can probably send you some, mix it and clean the area real good then apply it. I can get you instructions too.
[email protected]
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 07-16-2005, 03:36 PM
Starcraper
Guest
Posts: n/a
Hi, I also have that problem, except that the crack is around the tube that oil goes through. It cracked just around the bolt that holds the tube to the radiator. You suggested using epoxy. Are you sure that will work? I tried soldering it, but it doesnt melt, it becomes a sort of powder instead of melting.
