Old 06-06-2005, 09:01 AM
HD2NV HD2NV is offline
Exclamation 1998 Blazer Loud whining/howling sound
Maybe someone has posted this problem before but I couldn't find it when I searched around.
My 1998 Chevy Blazer 4X4 with 68k miles makes a loud whining/howling sound:
It sound as though it's coming from the drive train on the highway. It happens only on trips over 1 to 2 hours and sounds exactly like the loud whining semi tires make on the highway. It stops when I slow down to almost walking speed. Then there is a 'thunk' sound and it stops.
Thinking there was a correlation to the tranny, the last time this happened I stopped and engaged the '4X4 Hi', which also made it stop. It seems almost as though the 4X4 is trying to engage when in 2X4 mode.
Any ideas?
Old 06-06-2005, 09:30 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 1998 Blazer Loud whining/howling sound
Sounds like your hub bearings.
Old 06-06-2005, 11:11 AM
swalt's Avatar
swalt swalt is offline
Do some searching on the vacuum switch located above your transfer case and you have likely found your problem. It is the axle trying engage/disengage. Just don't let it go too long. Mine got so bad that it eventually would grind as I came to a stop. Sheared the gear on the front axle.
Old 06-06-2005, 12:31 PM
Do you think I need to replace the switch or just plug a vacuum line back in?
Old 06-06-2005, 09:48 PM
swalt's Avatar
Re: Re: 1998 Blazer Loud whining/howling sound
Replace the switch.
Old 06-07-2005, 10:05 PM
mtrotter70 mtrotter70 is offline
Check your vacuum lines also, starting at the vacuum ball and all connections.
It could be a cracked vacuum hose or bad connection.
Old 06-17-2005, 04:06 PM
Re: Re: Re: 1998 Blazer Loud whining/howling sound
Replace the switch.
I just wanted to say thanks. As near as I can tell the switch was the problem. When I took it out the lettle ball bearing was stuck clear inside the switch. It hasn't made the noise since then. I am going to drive it on vacation next week so I'll know shortly if that was it or not.
Thanks, again.
Old 08-07-2005, 06:02 PM
chigger23 chigger23 is offline
Any ideas?
Have them check the Spider Gear
Old 09-08-2005, 09:40 AM
blazer43314 blazer43314 is offline
Question Vacuum control valve
Do you have to take the transfer case off to get to the vacuum valve?
I'm having the same noise (goes away for awhile when you go in and back out of 4x4) then comes back 10 min. later.
I've looked and felt around, found the vacuum hose, goes to the top of the transfer case. Can't see how to get the valve out without taking the case off.
Old 09-08-2005, 12:20 PM
swalt's Avatar
Re: Vacuum control valve
The vacuum switch is on top of the transfer case and should just unscrew. Very simple.
