Old 04-16-2002, 06:49 PM
toolowintegra toolowintegra is offline
Need help on header install 911
i posted this in the integra forum but didn't get any help....
hey guys my DC sports CC 4-2-1 header just arrived and i want to install the bastard this weekend...... it is probably not as simple as just bolting it up...... i've heard that you have to do something with the o2 sensor..... relocate? ......also since the car is a 96 there is probably some rusting where the stock header connects to the cat converter.... will i need a torch???
can someone give me detailed instructions on how to install the header including any possible problems i might run into.... or if someone has a link somewhere where there is a good explanation. that would be great thanx.
---1996 Black Acura Integra----
Integra Type R Front Lip Spoiler
Autometer 5" SportComp Silver Tach w/Lite
Autometer Full dual pod pillar with A/F and Water Temp. Gauges
5Zigen Fireball Exhaust
AEM Cold Air Intake
DC Sports 4-2-1 Header
Eibach Sportlines
Tokico Blue Shocks
DC Sports Short Shifter
Strut Tower Bar
Titinium ITR Knob
98+ OEM taillights
Momo Pedals
Sony 700 Series CD/MD
shipping.... WW RS sides and rear
Old 04-16-2002, 11:08 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
its actually quite easy to install. now i dont know how you feel about getting burnt but it will be easier to break the bolts if the manifold is still hot. a little liquid wrench or some equiv and a breaker bar used with finess and they should come off. the holes for the o2 sensors should be pretty straight forward just make sure you dont drop them or grind them off anything when they are out and remember to put some anti-sieze on the threads when you put them back in just in case you have to replace one it will be easier to get out. when you torque the header down to the head go from the inside out. start at the middle nut and work your way out. do the middle then the nut closest to the left then the nut closest to the middle on the right and back and forth. remember to check them after a couple miles to to see if they are torqued down good after some use. dont forget to take the donut gasket off the old manifold at the cat and put it on your new one.
i do believe c-speed racing has a step by step but this is a new puter so i dont have the address. ask civsiguy i think he has one bookmarked.
Old 04-16-2002, 11:15 PM
thanx man, i need the advice..... can you expand on the o2 thing.... i'm still a little confused on what to do.....
and i will try to find that step-by-step thing you were mentioning
AEM Cold Air Intake
Eibach Sportlines
Tokico Blue Shocks
Strut Tower Bar
Titinium ITR Knob
98+ OEM taillights
Momo Pedals
Old 04-17-2002, 09:50 AM
ricodemus ricodemus is offline
your o2 sensor should be the only thing with wires on your header. just unbolt it from the stock one and put it on the new one. As far as relocating, maybe your DC has the spot for it farther down the pipe than your stock, but I'm not familiar with your manifold. worse comes to worse you may have to lengthen the wire.
I'm a lonely male who'll settle for any phony in a ponytail - MCPB
The b16 is in and running strong
