Old 06-06-2005, 12:35 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
PTE scm50
What do you guys think about this turbo? I'm getting ready to buy it from a friend for 650 installed. Obviously I don't have the rest of the mods needed, but once I have dsmlink, fuel, and fmic I think this turbo would be sick. It's on its third owner which is kind of bad, I'll check the shaft play as soon as I can.
The previous owner, a dsm buddy of mine, ran 13.3 at 112 on street tires. Dyno'd it mad 347whp and 329wtq, on race gas, kinda low for this turbo. The trap easily good enough for 12's. I "race" mainly on the highway. It will be on a daily driver than gets like 100miles a day.
now - 2000 civic
soon - 2002 is300
Old 06-06-2005, 01:04 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: PTE scm50
The older PTE turbos used a 270 degree thrust bearing which caused a lot of problems. I'm sure you've read about PTE turbos crapping out on people almost brand new. Recently PTE switched to a 360 degree thrust bearing which has reportedly cured the short life-span problem of their past turbos.
Since your turbo is on its 3rd owner, it obviously has the older 270 deg bearing and probably has quite a few miles on it. I wouldn't recommend buying it. You're better off buying a new turbo. Hell, slowboyracing has a sale on their t04e "50 trim" for $699 right now! These utilize the 360 degree thrust bearing too - http://www.slowboyracing.com/more.php?id=9&
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 06-06-2005, 01:59 AM
Re: PTE scm50
Thanks for the info I'll look into that turbo and other 50 trims. I'll find out which bearing it has because that turbo doesn't have many miles on it. Both upgraded to a 60-trim or higher within a few weeks.
now - 2000 civic
soon - 2002 is300
Old 06-06-2005, 07:39 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: PTE scm50
50 trims are plentiful, and $650 isn't that great of a deal. AGP, SBR, FP.. everyone offers a 50 trim. Make sure you are getting the hybrid 50 trim if you have a stock manifold.
Old 06-06-2005, 08:18 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
when i called PRECISION TURBO today he told me that they never used a 270 allways a 360.i called for a different reason but i remembered the post here so i asked.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 06-07-2005, 12:08 AM
Re: PTE scm50
Thanks for the info. After asking again, the turbo is about a year old, but has 0 shaft play. Should I still get it?
Jake? Kevin?
Any more input is appreciated. Thanks
now - 2000 civic
soon - 2002 is300
Old 06-07-2005, 01:53 AM
joemathews's Avatar
joemathews joemathews is offline
Re: Re: PTE scm50
I wouldn't pay $650 for it, personally. If you can't talk him down to $500 or below, installed, it's not worth it in my opinion. See if he'll take $500 for it, installed. If so, it's at least something to think about...if not, you can better spend that money toward a new turbo setup.
1996 Eagle Talon
Old 06-07-2005, 02:34 AM
Re: PTE scm50
Well, the information I received about this was from a thread on dsmtuners and then backed up by a couple of very knowledgable local guys here (non-dsm). Regardless, I think I would pass on this deal. $650 on any used turbo of this size is a bad idea, IMO.
95 GSX
Old 06-07-2005, 09:36 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: PTE scm50
I paid $700 for my turbo, injectors, and wastegate. I have a 56 trim (FP 3065) which will outflow that turbo by almost 20lbs a min. $650 for it isnt that great of a deal. Look around some more, if he includes injectors or something else into the deal and helps you install it then it probably wouldnt be that bad. Just my
Old 06-07-2005, 09:11 PM
Re: PTE scm50
thanks for the opinions
and who the hell did you sucker into getting that good of a deal? 700 for that turbo and injectors is insane!
now - 2000 civic
soon - 2002 is300
Old 06-07-2005, 09:37 PM
EclipseRST's Avatar
Banned
Re: PTE scm50
It was a friend. And I didnt sucker him into it. He was selling it for that, didnt talk him down any. I actually gave him $21 extra to cover paypal fees. So techniqually I paid $721 for it.
Old 06-07-2005, 10:37 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: PTE scm50
nice terbow! aka turbo
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
