Old 06-05-2005, 11:15 PM
g-ride-si's Avatar
g-ride-si g-ride-si is offline
ls swap help
im goin to do an ls swap soon like in the next month or so. ive got mounts and linkage what else do i need besides motor and tranny? i would really like to know about wiring... my hatch is an si i know i can use my ecu and harness for a zc and it will run ok but is an ls diff?
HELP PLEASE
Old 06-06-2005, 12:08 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: ls swap help
wiring is the same. just put your engine harness on the LS
you need LS axles, and to pop out the dust shields on the front hubs.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-06-2005, 12:24 AM
g-ride-si's Avatar
thanks for the help if im goin with a b18a can i use my ecu or would it be better to got with the teg?
Old 06-06-2005, 09:27 AM
EF You's Avatar
EF Life Giver
Re: ls swap help
the teg one, fuel maps are a lot better for the engine. but they both work
