coil???
I've got another question. I was going to prom and on the way the check engine light came on and all of a sudden I lost all power. I'd press on the gas and nothing. Shift down and nothing. I lost everything. The fan and all the electronics were working such as lights and stuff but I couldnt start the engine. It would try and start but not turn over. At first I thought I ran out of gas but when we put some in and tried it again, it still wouldnt start. This leads me to the coil pack. It's a 89 probe gt. I'm almost ready to shoot the car but It's my only transportation. I believe it's the coil pack or could it be the fuel pump? A little help please!!! Thanks-
sooo
so i replaced the coil and this is what it's doing. it's supplying the 12 volts from the battery to the coil but when i test it off the positive and negative posts on the coil i get hardly a reading..what's this about?? is it just trying to get some power? and i'm hooking up everything and still...i took the cable from off the distributor cap and held it like 1/6th of an inch away from the block and no sparks, could anyone help me out!!! I need this car to get around and it's really pissing me off! I dont know if it's the coil STILL or it's the wire, or the distributor cap or if it's not grounded right or what, is there anyone who could help me???
Re: coil???
you try boosting it.
93 FORD PROBE GT JDM manifold ported match 65mm TB Unorthodox Underdrive Pulley Hotshot headers 3' Exhaust all the way No cat Cold air intake K&N air filter Short throw shifter Eibach lowering springs FX Design Body Kit B&M Short Shifter Stage 3 Clutch MX-3 Flywheel Performace Wires and Plugs Synthetics Performance Rad and fan Mild Weight Reduction Coming this week: Performance Heads and Cams 3 angle head job Why does everyone have to piss on Ford.
