Old 06-05-2005, 09:50 PM
mindtwizzter mindtwizzter is offline
Send a message via AIM to mindtwizzter
car is sputtering
i have a 96 eagle talon esi and after a while of idiling at a dead stop the car will start sputter not moving the rpms enough to notice.....ok after i go to take off from a dead stop and i floor it the car sputters for just a sec and then takes off...can anyone give me some ideas on where to look at so im not looking in the dark
thanks for your help
Old 06-05-2005, 10:13 PM
macder macder is offline
Send a message via MSN to macder
Re: car is sputtering
99% of the time when a engine sputters in the low-end it's a simple ignition problem. Check your spark plugs and wires. If you haven't replaced them for a while, now is the time.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 06-06-2005, 08:13 AM
ok well the plugs are fairly new and the wires are fairly new....maybe this will help a lil, ok i pop the hood with the car running and i hear what sounds like spark inside the coil...when i hear the spark thats when the car sputters but this happens like every like 15-20 secs....need a new coil maybe??
any sugg. would be appreciated
Old 06-06-2005, 04:01 PM
ok guys i got the prob fixed just a simple plug without a head...geez how did that happen
