Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-05-2005, 08:41 PM
jono828 jono828 is offline
ABS Light
Over the past couple months, the abs light has appeared on my 94 si. If i turn the engine off and turn it back on, the light turns off. Could this be a faulty circuit or a more serious problem like the abs system?
Old 06-05-2005, 10:44 PM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
look back 6 threads. Bleed the system or in another words have a place flush out your brake fluid. if that doesn't work your in the same boat as the guy 6 threads back.. i doubt it would be the circuit
Old 06-06-2005, 05:40 PM
ok thanks i didnt kno if it was the same situation as the other thread about abs.
Old 06-06-2005, 10:33 PM
tetrahydro tetrahydro is offline
Banned
Re: ABS Light
my 94 Si does the EXACT same thing ive come to the conclusion that its a faulty ABS light, and i base that on absolutly nothing.
Old 06-07-2005, 02:02 PM
my fault I apologize I did not read your post carefully. Your saying you turn the car on, the abs light is on. You shut the car off, turn it on, then the light goes off. My car does the exact thing as well intermidently. It actually did it today. It might do it once or twice a month. I honestly don't know what it is. I have found that it does this in more humid weather or after it has rained outside. Is this the case with you both? Thats one characteristic of the problem that I can point out.
Old 06-07-2005, 02:26 PM
Gohan Ryu Gohan Ryu is offline
Re: ABS Light
My 92 Si did that when the brake fluid was low. Added brake fluid and the problem went away.
Old 06-07-2005, 04:45 PM
thanks for the posts
Old 06-08-2005, 10:54 AM
joellthomas joellthomas is offline
Re: ABS Light
As the brake pads wear, the fluid in the resevoir gets lower, or there is a leak.
