Old 06-05-2005, 08:39 PM
99silverado32 99silverado32 is offline
ls1
can u chang ls1 heads and cam onto a 4.8L
Old 06-05-2005, 09:25 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: ls1
no i don't believe so, I may be wrong though. I think the ls1 350 is totally different than the new 4.8.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 06-05-2005, 09:58 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: ls1
If you're gonna go thru all that trouble, why not just get a better engine?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 06-06-2005, 08:16 AM
01Blackerado 01Blackerado is offline
Send a message via Yahoo to 01Blackerado
Re: ls1
Yeah they will work!!!
Old 06-06-2005, 08:18 AM
Re: ls1
They heads are going to drop your compression ratio a little bit though. The cam will give you a pretty good notice in power.If I were you id just get the cam and some springs and call it a day. The loss in compression might take away what you are about to gain...UNLESS you decide to turbo, supercharge, or n2o feed it.
Old 06-08-2005, 02:55 PM
Re: ls1
i thought they would thanks for the reinsurrance
Old 06-10-2005, 11:56 AM
Rhymingmechanic Rhymingmechanic is offline
Re: ls1
I don't know the specifics of the LS1 cam, but be sure to consider your gearing and converter when picking a cam. A bigger cam shifts usable power to higher RPM's, and the effect is more noticeable with smaller motors. Has anybody ever built a fast-sounding dog by putting a big cam into a car with highway gears?
Old 06-10-2005, 12:02 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Re: ls1
Go to LS1TRUCK forum and they have done a lot of conversions and modifications. Allen Nelson is the moderator and has a lot of experiance with those type of issues.
Good Luck
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 06-13-2005, 08:26 AM
Re: ls1
Yeah its all good trust me, I wouldnt say it is if I wasnt sure!!! The cam produces its power from 1500-6000RPM where as the stock truck cam is in the idle to 5500RPM range. The stock convertor can be stalled to at least 2000 RPM!! People do the ZO6 swap alot in the trucks and dont have any issues, they lose a little bit down low but gain a substantial amount up top!!
