Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 06-05-2005, 03:34 PM
lrrman lrrman is offline
Question A/C switch
I have a 95 Cirrus and my A/C switch contacts are shot, the light on the A/C switch comes on but then goes off when I release the switch. The compressor clutch will only engage if I push and hold the A/C switch in, (the A/C switch is part of the fan switch). Anyone happen to know where I could tap into the wiring and parallel the factory switch with another toggle switch? The Haynes manual wiring diagram I have doesnt show the fan switch or the A/C switch.
thanks.
Old 06-11-2005, 11:04 PM
95 Cirrus Lxi 95 Cirrus Lxi is offline
Re: A/C switch
My 95 Cirrus does the exact same thing and I need to do something like that. Im guess what you would have to do is trace the wirers from the swich and pull them up in the radio compartement and then tie in your lines, those wires run back behind the radio and into a plastic tube.
