Old 06-05-2005, 02:02 PM
pipelinerr pipelinerr is offline
Send a message via AIM to pipelinerr
93 accord rough idle
car runs smooth when cold, when warms up it runs rough as if lean. EGR clean and closes any suggestions
Old 06-06-2005, 04:54 PM
Igovert500's Avatar
blue + red light magnet
Re: 93 accord rough idle
Hm, could be vacuum leaks, spark plugs, possibly o2 sensors. Also when is the last time you checked your thermostat?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-07-2005, 08:30 AM
ProMan ProMan is offline
First thing you can do is to check if the computer has any error codes stored. Start from there.
Old 06-07-2005, 09:21 AM
AccordCodger AccordCodger is offline
My mechanic performed what he called an "induction service" on my '93, and it cleared up the rough idle. I assume it involved cleaning? I didn't ask him (my bad).
Old 06-09-2005, 12:53 AM
94 Accord 94 Accord is offline
Is ur Accord an Automatic or Manual? If its an automatic it might have a vacuum controlled rear engine mount and when something in that system goes out you will get a rough idle. I know the 94 and newer Accords come with this rear engine mount for the automatic transmission Accords. The rod on my old rear engine mount broke then I bought a new rear engine mount and had it installed at the Honda Dealer and now my car idles nice and smooth The vacuum controlled rear engine mounts are designed to reduce idle vibrations.
Old 06-09-2005, 06:33 AM
Yeah, but it would tend to be WORSE when cold, not the other way round.
Old 06-09-2005, 08:17 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Re: 93 accord rough idle
Induction service:
A throttle plate cleaning and mixture adjustment, like I keep tellin' you all. But don't listen to me.....
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-10-2005, 08:15 PM
Re: Re: Re: 93 accord rough idle
Originally Posted by jeffcoslacker
Induction service:
you can adjust mixture on a 93?
Old 06-10-2005, 08:29 PM
Jeffcoslacker - can you?
Old 06-11-2005, 10:36 AM
Not sure. Haven't had to do that to Mom's '94 yet, and I don't remember any others I might have done. As a rule, the OBD I engines still have the screw on the throttle plate, but it is plugged with a freeze plug that has to be removed to access it.
Once you get to full feedback idle air bypass control (OBD II), there is no provision for it. Idle air mix is controlled solely by an IAC motor controlled by the ECM.
You'd just have to look and see if there is a cap where the screw should be.
...empty gun rack.
Old 06-12-2005, 09:38 PM
tanks ill look
Old 06-12-2005, 09:50 PM
Deadhead's Avatar
Deadhead Deadhead is offline
could there possibly be a sensor that is out of wack? i know that on my 86 Accord, the TW sensor went bad, and that caused a rough idle when it was hot, also it wouldn't start when it was hot. Just a thought.
1986 Honda Accord LX-i 5 spd
Completely stock... but i like it anyway, it's got a strong e-brake
www.cheesemit.us
http://www.cardomain.com/ride/862348/1
Old 06-14-2005, 02:09 AM
Actually Codger i was looking at it as if he were saying his car was "cold" like wen u first start it and warm it up. There is cold wen u first start the car and warm it up. Then there is the first few miles of driving which can be called cold also. I was mentioning that if he was talking about his car being cold before it warms up for the first time. You know when your car is first warming up the rpms are raised and the idle wouldnt feel rough wen the rpms are raised. I mentioned the engine mount if he was talkin about that senario. You know and then when the car warms and the rpms reach regular idle speed then u feel the rough idle. thats what i was talking about. i know there are many possibilities for a rough idle. the #1 reason i always hear for a rough idle is vacuum leak. im not sayin thats ur problem tho. i think what jeff said sounds like a good possibility to look into.
