Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-04-2005, 11:52 PM
Dudethejudge Dudethejudge is offline
Codes Again
Hi Guys,
I had my Check Engine Light on two weeks ago when I was driving on the high way (codes 12 battery disconnect and 65 Power steering switch failure). I didn't notice anything wrong with my power steering.
When I got home I noticed that the battery cover was pushing on the battery cables (battery slightly bigger than what it is suposed to be so it is pushing the cover). I disconnected the battery cables and reconnected them and the Check engine light didn't go off. A week later the light went off one morning untill last night, same senario driving on the high way.
I really appreciate any help.
Old 06-06-2005, 09:50 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Codes Again
Did you get a code 55, end of codes? If not, maybe you read the codes wrong. Anyway if you did read them correctly, you may have a wiring/connection issue. Check the power steering switch and make sure it is clean, free of debris, and seated correctly.
Old 06-06-2005, 11:35 AM
Thanks for your reply,
Actually I did get 55. I will try to locate the switch and look for any problems with it or the wiring.
L8r
Old 06-06-2005, 12:28 PM
On my 99 it is located on the back side of the power steering gear. You will need a 7/8" deep well socket (to prevent damage) to remove and install it. When installing, install by hand first and then torque it to 70 in/lbs. Oh before you do anything, disconnect the negative terminal first.
