Old 06-04-2005, 09:12 PM
silveradoman silveradoman is offline
Security light ON when tilting steering wheel
Very very weird thing happended today, I was driving along and decided to tilt the steering wheel up a notch, a couple of seconds later the security light came on and stayed on until I turned off the truck. Is it just me or has anybody seen this before??
Old 06-05-2005, 01:16 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
you may have a problem with your passlock system. could be nothing or it may need to go to the dealer. i wouldnt worry about it if it didnt hurt anything. did it go out after u shut the truck off and started it again? if so its nothing to worry about.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 06-06-2005, 11:43 PM
Re: Security light ON when tilting steering wheel
Yes it did, it did not turn back on after it sat for a few minutes, but I´m still wondering how tilting the steering wheel would do this
Old 06-08-2005, 03:31 PM
the only thing i can think of is there is a plug under there that could be loose. or the passlock wires could be pinched. have you done any work or wiring in your column or ignition harness. i would drop the lower dash and shroud on steering column and check all the connection and maybe jiggle them and play around while the truck is on and see if that causes it. hope this helps
Old 06-08-2005, 03:33 PM
the passlock wires may be in a small orange sleeve, or a gray sleeve. if not they will be a small yellow and a small black wire in the main harness.
Old 06-08-2005, 08:30 PM
They messed around under there when they installed the remote starter about 1 1/2 years ago, I´ll check it out, thanks!
Old 06-08-2005, 08:39 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Hey, do you remember how much your remote starter cost?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
