Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 06-04-2005, 04:05 PM
TVZ71 TVZ71 is offline
Another A/C ?
I have a 95 Sierra Z71. Last summer the A/C was working fine, I just tried it the other day and I get no cold air. I bought a recharge kit and hooked it up, the pressure was way high. What should I do next? What kind of ballpark figure can I expect to pay for service?
Old 06-08-2005, 08:56 PM
2000CAYukon 2000CAYukon is offline
Re: Another A/C ?
Did you add r134a before you noticed the pressure was too high? What is the pressure you are seeing?
Is the compressor cycling on and off?
//2000CAYukon
Old 06-09-2005, 06:55 PM
Re: Re: Another A/C ?
//2000CAYukon
It was high, I didn't add any. I think that the clutch is not engaging, Thanks.
Old 06-09-2005, 09:02 PM
Re: Re: Re: Another A/C ?
First thing to check is the pressure cycling switch on the accumulator. If you remove the electrical connector to the pressure switch and insert a jumper wire, see if the compressor kicks on. If so, you found your problem. The switch can be replaced without loosing any freon.
//2000CAYukon
Old 06-10-2005, 07:01 PM
Re: Re: Re: Re: Another A/C ?
//2000CAYukon
Without sounding stupid............. Where is the pressure cycling switch located? Thank you for your input, unfortunatley it is unseasonably hot and humid here in the magical mitten right now.
Old 06-12-2005, 01:37 AM
jmat1980 jmat1980 is offline
I have the same prob with an 03 blazer. I know where the elec. connector to the pressure switch is, but what do you mean by a jumber wire?
Old 06-13-2005, 12:37 PM
Re: Re: Re: Re: Re: Another A/C ?
The cycling switch is on the accumulator (a silver cylinder near the passenger side firewall).
//2000CAYukon
Old 06-13-2005, 12:40 PM
Re: Another A/C ?
The pressure cycling switch closes the circuit when there is enough pressure in the system (like turning a light switch on) and it opens the circuit when the pressure is too low (like turning a light switch off).
To test the switch, you need to complete the circuit. A jumper wire is a short piece of wire that you make to complete the circuit.
//2000CAYukon
