Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-04-2005, 02:52 PM
crabby760 crabby760 is offline
Massive Wheel Hopping
after i built my single cam vtec.... i have massive wheel hop
how can i prevent this i'm affraid i will be breaking axels left and right?
wat can i do or buy in order to stop the wheel hop
Old 06-04-2005, 03:39 PM
slate slate is offline
Send a message via AIM to slate
Urethane motor mount inserts helped my wheel hop a lot. And its a cheap fix. You can pick up a set for around $25.
NO! I DIDN'T BUY THIS CAR AFTER SEEING THAT DAMN MOVIE!
Old 06-04-2005, 03:45 PM
ok cool... anything else i can do to prevent wheel hop besides the urethane inserts?
Old 06-04-2005, 03:57 PM
97integrals's Avatar
97integrals 97integrals is offline
Re: Massive Wheel Hopping
Traction bars=no more wheel hop
Best traction bars made (in my opinion):
http://www.full-race.com/catalog/ind...?cPath=334_199
Old 06-04-2005, 08:30 PM
efSedan's Avatar
efSedan efSedan is offline
is there a less expensive option for traction bars for an ef? i don't want to get cheap shit but can't spend $450 right now.
Old 06-04-2005, 08:33 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
there is the L con and Jim fab also good parts for less.
I must agree full race is best my buddys got one on his rex its a badass part.
Old 06-04-2005, 08:42 PM
efSedan's Avatar
how does this knock off ebay part look?
http://cgi.ebay.com/ebaymotors/ws/eB...978700880&rd=1
Old 06-04-2005, 10:59 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Any traction bars made for a 92-96 Prelude? My wheels hop like bunnies. Especially when I hit 2nd too hard.
Old 06-04-2005, 11:46 PM
I have never seen any, but I know full race does a lot of custom work you could give them a call. It would probably cost a fortune but they might make you some.
Old 06-05-2005, 08:35 AM
Kven's Avatar
Kven Kven is offline
they have spherical bearings for the stock radius arm that you can use.
http://www.sbmsinc.com/race_shop.html
(Radius Rod bushings)
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 06-05-2005, 10:03 PM
Ace$nyper's Avatar
Banned
waahahahhah
take your coat off you live in my sig might as well get cozy!
Old 06-05-2005, 11:18 PM
duffman868 duffman868 is offline
if you are good at fabbing you can build you own traction bars they might not work as good as the other one but unless you are pushing over 300hp you should be fine with polyurethane mounts and a homemade traction bar
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 06-20-2005, 09:08 PM
i replaced my timing belt and they did the timing rite on the money... rite now my distributor is pushed all the way forward towards the intake manifold... and my cam gear is at 3 markes retarded
now when i floor it THERE"S NO POWER WHAT SO EVER!!!!
any ideas
Old 06-20-2005, 10:13 PM
any ideas
WTF??? why are you posting this in this thread?
Old 06-20-2005, 10:16 PM
this was my thread to begin with.....
