Old 06-04-2005, 11:06 AM
SComp23 SComp23 is offline
Headlight issue
I have a 1998 Chevy Blazer, and I have done a HID retrofit on it. However as you all know, when you turn on the high beams, the low beams switch off, and that is very bad for the HID components. I was told that you could put a diode somewhere within the wiring to prevent the low beams from turning off. Where can I get this diode, which diode do I get, and where do I then put the diode? If it matters I am running my HID's off of a homemade wiring relay. Thanks!
Old 06-18-2005, 09:38 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Headlight issue
You don't want the highs and lows running at the same time.
Huge stress on the electrical system.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-18-2005, 09:47 AM
Well my low beams are HID's running off of a relay connected directly to the battery, and also they only use 35w as opposed to the normal 55w 9006 Halogens. It is absolutely terrible to switch the HID's on and off when I need to use the high-beams. Do you know how to wire this up?
Old 06-18-2005, 10:17 AM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: Headlight issue
Lookie here and follow the instructions to have quadbeams or if you wish to bypass your DRL or AHL systems. Notice not all years are the same.
Thanks Chris and ZR2.com.
http://forum.zr2.com/ubb/noncgi/ulti...c;f=2;t=001272
Mark's Garage est. 1983
Old 06-18-2005, 11:14 AM
PBking82 PBking82 is offline
Re: Headlight issue
I do know of a kit that you can buy that makes your low beams stay on while your high beams are turned on. Here's a link. http://www.stylinconcepts.com/parts....categoryID=185
