Old 06-04-2005, 10:58 AM
phoenix1055 phoenix1055 is offline
Help.. Where is the Thermostat? 1997
OK folks.
Feeling a little dumb here.
Where the heck is the thermostat on a 97 cavalier?
Any pic available online?
Anyone good at explaining where it is?
Thanks.
Old 06-04-2005, 03:41 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Help.. Where is the Thermostat? 1997
# 23
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 06-04-2005, 04:23 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
On most cars it's just inside a metal housing that is usually connected to the main coolant line coming out of the radiator.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 06-04-2005, 06:10 PM
Beauty!
Thanks!!!!!
Old 06-04-2005, 08:07 PM
Lifted GMT-360!
I love having access to full diagrams like that!
Old 06-04-2005, 11:42 PM
Hey.. That IS great.
Any chance you have the legend that tells you what everything else is by number?
That way I can REALLY get myself into trouble changing out the water pump too.
Old 06-05-2005, 01:32 PM
deadBird's Avatar
deadBird deadBird is offline
#31 & #32... me thinks.
Old 06-05-2005, 02:35 PM
Yep.. I was thinkin 31 and 32 myself.
Would love to have the legend that ID's the numbers that goes with that pic... Must be from the factory service manual is my guess
Old 06-05-2005, 02:36 PM
Old 06-06-2005, 01:23 AM
Lifted GMT-360!
Ask and you shall recive...
(1) Piston Rings
(2) Piston
(3) Piston Pin
(4) Connecting Rod
(5) Connecting Rod Bearing
(6) Connecting Rod Bolt
(7) Coolant Jacket Plug
(8) Clutch Housing Pin
(9) Cylinder Block Oil Gallery Plug
(10) Plug
(11) Cylinder Block
(12) Camshaft Rear Cover Bolt
(13) Camshaft Rear Cover
(14) Camshaft Rear Cover Gasket
(15) Plug
(16) Coolant Drain Plug
(17) Oil Level Indicator
(18) Oil Fill Tube
(19) Oil Fill Tube Nut
(20) Oil Fill Tube Seal
(21) Bolt
(22) Coolant Inlet
(23) Thermostat
(24) Thermostat Seal
(25) Sub Assembly Coolant Inlet
(26) Coolant Inlet Bolt
(27) Coolant Inlet Gasket
(28) Connecting Rod Nut
(29) Connecting Rod
(30) Connecting Rod Bearing
(31) Coolant Pump Gasket
(32) Coolant Pump
(33) Coolant Pump Bolt
(34) Coolant Pump Pulley
(35) Timing Chain Tensioner
(36) Timing Chain Tensioner Belt
(37) Timing Chain Tensioner Bolt
(38) Camhsaft sprocket Bolt
(39) Camhsaft Sprocket Washer
(40) Camshaft Sprocket
(41) Fuel Pump/ Oil Pressure Switch
(42) Oil Pressure Relief Valve
(43) Camshaft
(44) Camshaft Thrust Plate Bolt
(45) Camshaft Thrust Plate
(46) Camshaft Sprocket Lock Pin
(47) Camshaft Bearing
(48) Crankshaft Position Sensor
(49) Crankshaft Position Sensor Bolt
(50) Lifter Anti-Rotation Bracket
(51) Oil Filter
(52) Oil Filter Fitting
(53) Lifter Anti-Rotation Bracket Bolt
(54) Ignition Coil Bolt
(55) Ignition Coil
(56) Valve Lifter
(57) Valve Push Rod
Old 06-06-2005, 01:26 AM
Lifted GMT-360!
I also have picture diagrams of how to remove the engines, breakdowns of the lower block, upper block, and cylander head. For the 2.2 OHV's, 2.4L and ecotec.
Old 06-06-2005, 03:42 PM
You da Man!!!!!!!!!!!!!!
many thxs.
