Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-04-2005, 07:23 AM
Dirty Harry Dirty Harry is offline
jdm d15b vtec MAP sensor
I just got finished dropping in my jdm d15b into my 92dx hb. I'm about to connect all the plugs and what not and I saw that the MAP sensor is located on the throttle body (I think thats what its called) on the engine itself. The old engine that was in there before had the MAP sensor on the firewall. The wiring harness that came with the new engine has the plug for the sensor comming out of the harness itself. On the other sensor (the one on the firewall) the cable goes directly to the ecu I think. Do I have to rewire, or will it work if I just use the connector that comes out of the wiring harness on the engine? I'm using the p08 ecu that came with the engine. Thanks for any help, I cant wait to get this baby running
Old 06-05-2005, 08:57 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: jdm d15b vtec MAP sensor
T the vac source into the charcoal canister or fuel pressure regulator line.
T it or go buy a 94+ls throttle body.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
