Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-04-2005, 01:40 AM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
car keeps dying. need help!
i just installed a 70mm bbk throttle body on a 00 civic si. when it hits vtec the car will bog and die. when i try to start it i have to push the gas pedal a little and then itll start again. what can be wrong? im guessing its the throttle position sensor. how do i check to see if its the tps?
Old 06-04-2005, 02:50 AM
V T E C H's Avatar
V T E C H V T E C H is offline
Re: car keeps dying. need help!
ummm, if you push in on the clutch and coast, dose it die too? that would be an IAC valve problem, at least it was in my case.
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 06-04-2005, 03:46 AM
yea it dies when i push on the clutch too. bbk has these 2 vac ports on the top next to the map sensor that the si doens't use. it sucks in air when the car is on. am i supposed to plug it to prevent it from sucking air
