Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-04-2005, 01:10 AM
763kelly 763kelly is offline
Unhappy 4.6l ticking and missing
I have a 1997 cvpi with 153k miles. The engine started ticking about 20k
ago. I ran seafoam through it and it made the ticking worse. It is coming from the #8 cyl. so i tried replacing the injector. The car has developed a noticable miss now. Am i right in assuming that this is a burned valve? Do I have to pull the heads to repair this and if so would i be better off doing a swap to performance improved heads while i am at it?
Old 06-05-2005, 11:05 AM
wasabiboys's Avatar
wasabiboys wasabiboys is offline
Send a message via AIM to wasabiboys
Re: 4.6l ticking and missing
Hmmm...maybe. I would look at the cost and the gains from the cost. See if its benefically!
1992 Crown Victoria 185,000 Miles with Flowmaster 40s , K+N,
1992 Volvo 244 2.3L 107,000 Miles Borla, Ram Air, K+N, PIAA Fog Lights
Old 06-14-2005, 07:26 PM
radioman2002 radioman2002 is offline
If you like the car try and get a wreck from somewhere, (paid about $1,000.00 for one with 40k on it),or a junkyard motor. I have one with 185K that my nephew blew up, I am going to rebuild it in the car, sounds like the overhead cam bearing.
Old 09-19-2005, 09:37 PM
beardydragon beardydragon is offline
Send a message via AIM to beardydragon Send a message via MSN to beardydragon
on my 95 crown vic cylinder 4 was missing i replaced the plugs and wires and that did the job. if its not that then you might need a valve job which can be a pain in the ass.
Old 09-19-2005, 10:08 PM
ModMech's Avatar
ModMech ModMech is offline
Ticking AND missing may very well be an ejected cam follower. Another possible cause, while very rare, is a failed timing chain tensioner.
Until you do a compression or leak-down test, I would not "fix" anything else.
Old 10-02-2005, 10:03 AM
Fullyinvolved Fullyinvolved is offline
I had a ticking from my engine once, I also thought it to be my injector. Turns out the guy at the shop put the sparkplug in loose, causing the ticking noise, which eventually led the the spark plug blowing out and causing a HUGE headache that I wouldnt wish on my worse enemy.
The question is did the ticking stop when you changed the enjector. There also was a loss of power as the loss of compression. If this is the case you need to try and corect it before the threads get dammaged and you have to pull the head to fix it. Which believe me is not fun!!! GOOD LUCK, hope i have helped!
Never argue with an idiot. They will bring you down to their level, and then beat you with experience
