Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 06-03-2005, 10:43 PM
Syn48 Syn48 is offline
wastegate pipe?
Hey all just got my exhaust manifold today and i was wondering how i go about puting the wastegate tube in. What size pipe is recomended and where would i bring this to be cut and welded. Or if there is an alternative place to put the wastegate please let me know. i though about the o2 housing but can the stock 3g housing be used?
Old 06-07-2005, 10:39 AM
2002EclipseRS's Avatar
2002EclipseRS 2002EclipseRS is offline
Are you running forced induction? If not. I dont think there is a point in having a wastegate. Am i right guys?
Made the switch from Mitsubishi -> Honda (acura)....so glad i did!
Old 06-07-2005, 11:12 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: wastegate pipe?
he is putting together a custom turbo kit if i remember correctly
Old 06-07-2005, 11:59 AM
yes iam puttiing together a custom turbo and i have almost all my pieces now and i am ready to begin the prep for the actuall install. i would like to run the wastegate off the manifold and i would like to know what type of tubing should i use. i am going to put it off the number 1 runner and i just need some info on tubing and possibly how much it might cost to have this drilled and welded on.
thanks
Old 06-07-2005, 03:37 PM
Re: wastegate pipe?
are you wanting to know where to put the dump tube?
Old 06-07-2005, 09:11 PM
Here i will show you a picture ofwhat iam trying to acomplish i understand where i want to put the tube i just need to know what thickness i should use and how much it might cost me to have the hole drilled and the tube/flange welded on.
heres the pic ( i know this is possibly the most hated seller on ebay but this is what i am talking about)
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
Old 06-08-2005, 11:38 AM
Re: wastegate pipe?
just use 304 stainless steel(might be expensive though). couldnt tell you how much it would cost somebody to do it since it varies from shop to shop
Old 06-17-2005, 11:01 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: wastegate pipe?
Did you do a 4g63 swap into a 3G?
Old 06-18-2005, 12:16 AM
evil6remlin evil6remlin is offline
Re: Re: wastegate pipe?
No he didn't but 2G exhaust manifolds will bolt right up to the 4g64 in his car.
Old 06-18-2005, 05:46 PM
not necessary
Old 06-23-2005, 07:05 PM
Re: wastegate pipe?
is it the v6 or 4
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 06-24-2005, 07:30 AM
is it the v6 or 4
4cyl
