Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-03-2005, 09:29 PM
72 rs's Avatar
72 rs 72 rs is offline
Unhappy problems starting.....stumble on accleration
hey guy im new to imports and have a 99 eclipse fwd non turbo 2.0 liter.
now that thats out of the way i need some help....... im having probs. with my car starting. Sometimes it just wont start, whent finally starts it revs to about 2500 rpm for about 2 sec. then idles down .....i put new plugwires and plugs in it when it flashed a missfire code fore cyl. 3. this fixed the prob for a while but its doing it again. 2nd prob is when its not doing that it seems to have a stumble on acceleration ( like it stops firing for a sec.) . its very slight just as you touch the acclelerator pedal then it stops as you pass this point.
other than the oil leak the car runs great.
any help would be greatly apreciated.
Old 06-05-2005, 10:16 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: problems starting.....stumble on accleration
Just FYI... eclipses,talons,lazers are NOT imports... they are made in the USA... in japan an eclipse would be an import to them....
Sorry I have no help as to your misfire/stumble problem....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 06-06-2005, 06:40 AM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
Re: Re: problems starting.....stumble on accleration
Does the acceleration stumbling occur just when you press down the bedal in the beginning even when the car is warmed up or after a few accelerations?? Mine ALWAYS barely goes when I shift into first and put the gas down...it does nothig but bog...but after a few seconds the bogging goes away. Is that how yours is or does it always bog when you accelerate?
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
Old 06-07-2005, 09:25 PM
72 rs's Avatar
it does it whenever it wants....warm , cold, it dosent matter. it just does it when you start off from a stoplight etc. i had a leaky upper rad hose on the engine end and it leaked on 2 sensors right below it. these 2 sensors coroded up pretty bad, one is so bad i cant get the conector to come off the sensor. could this be a possable prob. ??
spyderman...........sorry if i insulted you or anyone else by calling it an import......i know its an american product......im a chevy truck guy at heart and it came out wrong while typing
again any info on this be apreciated
Old 06-08-2005, 03:29 AM
Benag Benag is offline
If I were you I would fix the sensors soon even if they aren't causing the problem. Also, my car runs really slow in take off when it is cold, but diagnostics says it is the MAF sensor so I am ordering one from ebay. Those things are around 500 new!
'95 Eclipse GS-T
5-Speed
Boost, air/fuel gauge.
