Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 06-03-2005, 08:38 PM
ne84elcamino ne84elcamino is offline
strong gasoline smell
My 84 El Camino stock 305 4bbl Quadrajet, automatic transmission, has a very strong gasoline smell after it has been driven then turned off. I cannot see any leaks, but it seems to be coming from the carburetor area. Anybody know how to fix this?
Old 08-11-2005, 01:22 PM
Bruce Holder Bruce Holder is offline
Re: strong gasoline smell
I had the same problem for a long time until someone suggested it was the fuel pump....yup it was.
Old 09-15-2005, 07:01 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Look for a leak at the fuel inlet at the carb first. Also q-jets have soft plugs at the bottom of the fuel bowls, they are notorious for leaking and dumping gas into the manifold. Check your throttle linkage and return spring for a bind, make sure it fully closes when the engine is off.
Bob
Old 09-26-2005, 04:34 PM
TRIK-56 TRIK-56 is offline
Also, check the short rubber gas line that runs from the metal fuel line to the fuel pump for cracks or deterioration.
