Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-03-2005, 07:55 PM
penske penske is offline
engine swap
has anyone ever seen a chevy engine and trans in a rodeo. i am fixing to try to put one in a 95 rodeo, but dont know which to use. any suggestions.
Old 06-03-2005, 08:31 PM
Ramblin Fever Ramblin Fever is offline
Re: engine swap
The 91 & 92 Rodeo's ARE Chevy/GMC engines; the 3.1L.
So it's possible you may be able to find a 3.1L that'll fit right in - somewhat smaller then the engine you had in your 95. If your's was a 3.2L.
If you had a 2.2L, then the 3.1L is a giant leap.
Don't know about bigger engines.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 06-03-2005, 08:46 PM
rodeo02 rodeo02 is offline
You dont hear too much about engine swaps on rodeos. I don't think anything is drop in & go. Check this fine link: http://myweb.cableone.net/bcanderson...uroraSwap.html
I suspect it would be a ton of work to tie in the driveshaft & get all the cabling and plumbing set up properly. You know how it is, anything is possible with enough $$$$!
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-04-2005, 09:57 AM
im looking to drop a carberated engine and hopefully an automatic. im thinking the biggest challenge will be the driveshaft. if the earlyer rodeos had chevy engines would the isuzu trans bolt to them. my 5sp in the 95 is new and i would like to use it. i did have the 3.2 which was very stronge, but did not last
