Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-03-2005, 05:00 PM
sparticus1262 sparticus1262 is offline
Battery Dead?? I disconnected both neg/pos?
I just the Camshaft position Sensor and the car started fine. But when I shut off to crank again nothing? Looks like lites are dim but then start to get brighter on the dash. I know it says only disconnect neg but I disconnected pos. also so I had more room to wrk. Do I just need to wait awhile with both connected?
Old 06-04-2005, 07:48 AM
Fractured1 Fractured1 is offline
I didn't matter that you disconnected both teminals..disconnect both again and clean the battery terminals and the cables, sounds like they are a little dirty or corroded...you should be fine
Old 06-04-2005, 07:40 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Battery Dead?? I disconnected both neg/pos?
Sounds like you didn't tighten them good enough. Make sure your terminals are shiny and clean, as mentioned, and that they are on their tight.
