stalls with brake
hey guys..... um my 88 4.3 stalls when i'm like goin slow and hit the brake...... usally when i start off or back up and step on the brake it stalls slowly slowy dies...... got any ideasss.. i cleaned my fuil injecters just with the spray can..... but its still doing it i have no idea umm it needs a tune up really bad tho you think that muight be the problem or lack of air like on of the hoses?
Re: stalls with brake
Buy a haynes/chiltons manual, it has many troubleshooting items that you can check.
my 4.3 did the same thing.. i got a manual so i kept it revved and kept it running.. i replaced the Throttle Possition Sensor and it helped somewhat.. since then ive replaced the injectors, air cleaner, fuel pressure regulator and fuel filter... if i were you id start with the fuel filter and check ur air filter.. those r the easiest.. if not fuel pressure regulator might be clogged or your injectors (which are $120 a pop) and theres two of them... if u have a haynes manual look in it and it can tell you how to check all these
http://www.cardomain.com/memberpage/579272 (my truck) |
