Old 06-03-2005, 01:35 PM
wvrefugee wvrefugee is offline
Question 93 Feul line leak. Hard fix? Help!
Thanks to all contribute to this great forum.
93 2.2l
Line is leaking right under drivers side door. If I'm not mistaken, looks as if its one piece running all the way from the tank to engine.
Has anyone ever replaced one of these lines. Hard fix? Does the tank have to dropped. Also, could I get a quick fix by wrapping a piece of rubber and crimp down with a tiny hose gasket. (This worked on a water line once)
Any input will be greatly appreciated.
BTW, anyone know the ballpark cost of this feul line.
Old 06-03-2005, 01:50 PM
public's Avatar
public public is offline
Re: 93 Feul line leak. Hard fix? Help!
You can buy straighd metal line at any parts store. then just cut out the bad section and replace. IF you can find rubber line for fuel injection this is a 20 minute repair. You will not need to drop the tank.
Good Luck.
Yes, I am retarded.
Old 06-03-2005, 02:04 PM
Are you talking about cutting the bad section out and replacing w/ new. If this were done, how would you connect the new with the existing lines?
Thanks
Old 06-06-2005, 02:23 PM
cousincletus cousincletus is offline
You could try finding high pressure fuel line, cutting the fuel line where it is leaking, and double clamp the rubber fuel line in place. I don't see any reason why this wouldn't work.
Old 06-06-2005, 06:28 PM
Thank you!
Old 06-06-2005, 07:42 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Thanks
You should try welding it.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
