Old 06-03-2005, 12:36 PM
aharte aharte is offline
question
how do i take out heater controls in 92-95 civic,do i have to take out dash?
Old 06-03-2005, 01:23 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: question
http://www.honda-tech.com/zerothread?id=661308 Start looking after he got the cluster out, and no you don't have to take the dash out.
Old 06-04-2005, 10:06 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
You do not have to take the whole dash out, though if you ever need to do that I can give you some pointers on that too.
For the climate controls...First remove the radio and the lower console cover. There are 3 screws (bigger ones) that hold it in, two near the front and 2 near the rear. You'll need to remove those. You'll also have to disconnect the heater control cable from under the glovebox, and the 2 wire plugs in the back. Once the screws are out and the heater cable disconnected, it should come out If it starts to stick, sometimes the little gold screws stick, there are 4 of them. They look the smae where they are in, but there are 2 shorter ones (the forward 2) and 2 longer ones (right behind the smaller ones). You don't need to remove those, but smetimes it helps it slide out easier. Also, remove the interment cluster bezel will allow you to shine a light in from above and get a better hand in there to remove the plugs.
If you realy have issues witt he plugs, you can disconnect the harness from the plug uner the lower console, and there the smaller plug of it from up under the radio area. This will allow the harness to stay attacted to only the climate controls, so you can slide them out and remove the plugs once it's out. Installation is reverse of removal.
Sorry I don't have any pics of the process, I didn't take any when I had mine out.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 06-07-2005, 12:53 PM
Re: question
thanks for the help
Old 06-11-2005, 09:14 PM
Honda God
Re: Re: question
Originally Posted by aharte
thanks for the help
No problem, I hope we helped. It's not too hard to remove the climate control.
EPR Member 4 Life
