Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-03-2005, 11:18 AM
MKIII87Turbo MKIII87Turbo is offline
Rough Idle/Missing
Its a stock 95 GST. Yhe story. About 3 months ago my son calls up and says all of the lights on the dash are on and won't start. I brought over a new battery and installed it. The alternator was putting out 14.2 volts at the time. The SRS light has neve gone out since. About a month ago the alternator was squeeling really loud and the dash light came on. Replaced the altenator only getting 2. volts. Since then the car has been idleing rough and misfiring. If I disconnect the battery and reconnect, it will run better for awhile and go back to the rough idle/missfire. I don't know how to pull codes on this car and did a search on how to do it with everyone saying to do a search or go to AutoZone. How are the codes pulled? What could be his problem?
Old 06-03-2005, 01:07 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Re: Rough Idle/Missing
The codes are pulled by hooking a code reader up to your ob2(diagnostic)port. Then they will print out what the codes mean. Their is a another way by reading the check engine light when its flashing.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 06-04-2005, 07:55 PM
Pulled the codes. Nada. Replaced the plugs from Bosch Plats to Bosch Coppers. No more idle problems.
