Old 06-03-2005, 10:48 AM
kita23 kita23 is offline
Free mod
I took out my throttle body screen today and it really does improve response when I hit the gas and the car also pulls a lot more and rarely downshifts when going up hills. Good Free Mod from ZZ Performance.
Old 06-03-2005, 11:50 AM
hawkgs hawkgs is offline
Send a message via MSN to hawkgs
Re: Free mod
Hello, what is exactly the throttle body screen?
Old 06-03-2005, 02:08 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Free mod
Here's an old message thread on the pros and cons of the throttle body screen. There are pics to help guide you along. No need to re-invent the wheel.
http://www.automotiveforums.com/vbul...le+body+screen
Thrasher CAI, DHP v1.0 ECU,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS,TB spacer,
MSD 8.5mm wires, Autolite 104 spark plugs,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 06-03-2005, 09:24 PM
Re: Re: Free mod
I have no regrests doing this free mod to my car. the response is a lot better when i hit the gas. I can see no cons to this modification as stated in that big and long research remark.
Old 06-03-2005, 09:44 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: Re: Free mod
I don't think that was a "big long research remark". I think it was the right answer to the question asked. I can't find one thing wrong with it.
Tell you what, reread it. Let us know what you think.
I tried your way a long time back, worked good, for a short time. But as I said. Reread it.
Thanks
Old 06-03-2005, 10:19 PM
BNaylor's Avatar
Re: Re: Re: Re: Free mod
Here's a fact:
Removing the throttle body screen does nothing and its removal is subjective. There's always two sides of the coin.
HP gains = Zero
Torque increase = Zero
0 - 60 ft or ET improvements = Zero
Most of us have been there and done that (BTDT).
Timeslip 08/12/06
Old 06-04-2005, 10:52 AM
Well i read it again and i decided to put the screen back in. i just dont want to take the risk of injuring my engine in any way.
Old 06-04-2005, 08:41 PM
BNaylor's Avatar
Good choice, though it probably would not damage the engine.
There are 3 typical symptoms without a screen:
Poor idle
Possible MAF (Mass Airflow) sensor DTC error
Possible lean condition
The primary reason why the screen removal doesn't do much is this:
If your car is stock without a re-programmed ECU or calibrated MAF sensor like on the ZZP Stage 2 Throttle Body or a Granatelli GMAF, the stock ECU will learn the change/mod over a drive cycle of up to 200 miles and negate the mod. The same thing happens when you put in a K&N air filter. Seems great at first but in the end nothing. The stock MAF leaves alot to be desired because it is very imprecise and uncalibrated.
I hope the info helped and good luck!
Timeslip 08/12/06
Old 06-04-2005, 08:57 PM
Re: Re: Re: Re: Re: Free mod
Poor idle
thank you for the advice. i have a problem though, when i sit at a light my temperature gauge goes from 16 to 210 in no time flat and then cools down once the air hits the radiator. i tried to bleed my coolant system and it worked fine for a day or two n then it happened again. if i install a 180 thermostat will it take care of the problem?thank you for all your help
Old 06-04-2005, 09:13 PM
BNaylor's Avatar
Re: Re: Re: Re: Re: Re: Free mod
Sounds like the thermostat is sticking but I'd go with the 180, regardless. How old is your coolant and is it Dexcool? Have you ever done a flush? And is this with the AC on or off? What model GP do you have and engine, mileage? Any mods?
Timeslip 08/12/06
Old 06-04-2005, 09:59 PM
Re: Re: Re: Re: Re: Re: Re: Free mod
This is with the A/C off. It is Dexicool. Its a 1997 Grand Prix GT with 63400 miles. I have not done any mods other than coesmetics because of money. im only 18 here.got to go to college first. but i was hopeing the would be the beginning of "the modding bug". I do not know how old the coolant is. my guess would be maybe a year.
Old 06-05-2005, 07:12 AM
BNaylor's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Free mod
I noticed you mentioned the temp. gauge goes from 16 to 210 in no time flat. Is the engine already warmed up or cold when you get this indication?
Timeslip 08/12/06
Old 06-05-2005, 09:06 AM
Re: Re: Re: Re: Re: Re: Re: Re: Re: Free mod
If it doesn't go above 210, that is pretty normal for a 195 Tsat, and it's still in the normal range. Found out with the 97 if your stuck for anytime, it will run 210. But, shouldn't go any higher. It's been a while since I ran a stock Tstat. I'd try starting it in the driveway. Let it warm up and see if it goes up and then down. That's the tstat opening and closing. Just keep a damn close eye on it. If it goes to 210 and then down, that's normal. If it doesn't, check to see if fan is coming on. Then flash and replace Tstat.
Good luck.
Old 06-05-2005, 09:42 AM
BNaylor's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Free mod
Originally Posted by kustomkid54
If it doesn't go above 210, that is pretty normal for a 195 Tsat. Found out with the 97 if your stuck for anytime, it will run 210. But, shouldn't go any higher. It's been a while since I ran a stock Tstat. I'd try starting it in the driveway. Let it warm up and see if it goes up and then down. That's the tstat opening and closing. Just keep a damn close eye on it. If it goes to 210 and then down, that's normal. If it doesn't, check to see if fan is coming on. Then flash and replace Tstat.
Good luck.
I agree Jim, 210 is normal with the stock TS. But what threw me off is his rapid upswing fron 16 to 210 degrees. Temperature rise should be linear as the engine warms up. Don't you think he'd be better off with the 180 degree TS anyways. What say you?
BTW - Your suggestion to go with the 160 TS worked out great at the track. Now if I can just keep that supercharger cool.
Timeslip 08/12/06
Old 06-05-2005, 11:00 AM
Good luck.
this is already when the car is warm, running more than fifteen minutes. this week when i have time im going o install a 180 tstat. ill let everyone know how it went. thank you for all your help
