Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-03-2005, 09:10 AM
lucaswhunter lucaswhunter is offline
ticking noise... not timing belt
I just got a call from my mechanic... I took in my rodeo to get the t-belt changed, and it turns out it is not bad. He sais something about an "oil flow back valve?" does that make sense? he said that they are plugged, and not getting enough oil in. he said i may want to try a detergent in it.... any ideas? im gonna change oil and stuff this weekend so its a good time.... I have 120k on it.
Old 06-03-2005, 10:34 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: ticking noise... not timing belt
buy some Seafoam.
Dump in a half can and then take it for a 30 minute drive and then change your oil asap (while it is good and hot).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-03-2005, 10:55 AM
thanks! I will try that... Ive had good experience with seafoam in my old jeep.... should i pour it in the crankcase? or use through pcv?
Old 06-03-2005, 11:27 AM
Isuzu Guy
I typically just pour it into the crankcase, but if you want to suck some through the PCV, I'm sure that will be fine too.
-Ryan
Isuzu Moderator
Car Show Tips
rodeo02 rodeo02 is offline
Lucas, if she's ticking really bad due to a collapesed lifter (they get clogged easily on the 1993-1997 3.2), I'd dump the oil, slap on a new cheap oil filter, fill it with a cheap 5w-20 (thin!) motor oil and a ton of seafoam. Run it for 1/2hr, around town, etc, until it's good and hot. Dump it, and run a good 5w-30 and a good filter. This may take a couple applications.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-03-2005, 11:57 AM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
Re: Re: ticking noise... not timing belt
Correct me if I am wrong, but if your are sucking it up through the pcv then it is going in to the intake manifold, not the crankcase. Unless of course you are saying remove the pcv and dump it in the hole, which I don't know why you would do that, it is the same as putting it in the oil fill, just a smaller hole to try and get it into.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 06-03-2005, 08:17 PM
Re: Re: Re: ticking noise... not timing belt
Originally Posted by iskiuskiweski
Correct me if I am wrong, but if your are sucking it up through the pcv then it is going in to the intake manifold, not the crankcase....
You got it. That will clean the heck out of your combusion chamber, but it wont hit the 'oil side' of the engine in any quantitiy. Really, the only way to clean the common chamber/intake on all of the 3.2/3.5's is to remove the top, or the whole thing & clean it by hand. For the oil burner 3.2/3.5's you need to load each cylinder thru the spark plug hole with seafoam & let it sit over night.
G/luck
Joel
Old 06-06-2005, 06:54 AM
Good News! I poured a bottle of Seafoam in the crankcase and drove it for about 30 miles, and at mile 25, the engine hesitated, and blew a puff of smoke, after that it ran like a top and ticks no more... I changed the oil afterwords and it was like molasses coming out, everything sounds great now! thanks for your help!!!
Old 06-06-2005, 08:05 AM
So you put the whole bottle in? Just wondering.
Old 06-06-2005, 02:48 PM
I did use the whole bottle.... Risky, but it worked... (thankfully)
Old 06-10-2005, 06:46 AM
tygger tygger is offline
Can Seafoam be added to old oil that's in the engine or should I change my oil, put in Seafoam, run engine and change it again afterwards?
Old 06-10-2005, 06:54 AM
I ran it in the old oil for about 50 miles and them emptied.... change it hot, and the syrup will come right out!
Old 06-10-2005, 07:56 AM
No sense in ruinning new oil, I normally put in with the old right before my scheduled oil change. Once every 12k or so.
Old 06-10-2005, 08:53 AM
Ramblin Fever Ramblin Fever is offline
Just curious if any one else is leary of using Sea Foam and other engine cleaners
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 06-10-2005, 10:05 AM
Isuzu Guy
I was always in the camp of no additives for a long time.
When my old truck started to stumble at idle, I changed out the plugs and wires, no help. With 150k on the engine I was at a loss of what to do. So I tried a couple of bottle of injector cleaner and wham, it was just like new again.
Adding stuff to the oil on an old engine (over 120K) is a bit risky. But if you have kept up with 3-4k oil changes since new, I honestly don't think adding sea foam (or the like will hurt it).
Most SUV (for sure Isuzu's), carbon up the engine very quickly. I'm surprised how fast my oil turns black on my Amigo, yet my wives 13 year old Prelude si oil is usually very clean. Also, after reading about folks dumping their engines due to lack of oil, and me personally having engine PING with one 13k I knew I needed to start doing something to keep the carbon down. That is where Sea Foam came in. Add a half can go for a 30 minute drive, drain and watch the dark black water junk flow out.
-Ryan
Isuzu Moderator
Car Show Tips
