Old 06-03-2005, 09:07 AM
brots06 brots06 is offline
Send a message via AIM to brots06
What exaust should i get??
Hi-
what brand/size exaust should i get for my '99 grand am gt 3.4 with dual exaust. I am looking for a power increase and a good deep sound, i dont want that high pitched sound that you get with like an insert on the end. I am going to have a local place install it for me and i would like to have some knowledge on this type of thing before i go. And if i do get a new exuast will i notice a power difference?
Old 06-03-2005, 11:10 AM
Knifeblade Knifeblade is offline
Re: What exaust should i get??
Well, honestly, if ya just go from the cat. back, hp is too little to spend lots of $$$ on. You need to at minimum get a free-flow cat. before the exhaust for any gain to be seen.
Old 06-03-2005, 11:19 AM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
SLP makes a great cat-back exhaust system for our car. With a typical 3.4 and an SLP system, you'll see gains of around 10 horses at the crank - the power will be more prevelant in the higher RPM's. A full SLP system usually runs 300 to 400 $$. They sound great, add a decent amount of power, and will give you better mileage. If you were to run a SLP system with a magnaflow high-flow cat (like Tam said - usually around 100 $ i think), you'd probably get about a 15 hp gain at the crank.
Old 06-03-2005, 02:07 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
You want power, ehh......RSM Racing has just introduced a set of headers for the 3.4, add a 2.5" ehxaust pipe along with Ridenour's recipe and you'll have a nice boost in power. And like Knifeblade said, if you keep the stock cat it won't be worth the money. Just remember before you do anything else you should at least have a good intake system, there's no point in having good flow out the tail end if you can't get a decent amount of air into the engine in the first place.
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
Old 06-03-2005, 02:50 PM
you guys keeping on saying cat, what is the cat?
Old 06-03-2005, 02:56 PM
and im putting in a cold air intake this weekend, so the engine will be getting enough air
Old 06-03-2005, 03:00 PM
CharlotteHawk CharlotteHawk is offline
Re: Re: What exaust should i get??
catalytic converter
Old 06-03-2005, 03:45 PM
Re: Re: Re: What exaust should i get??
Originally Posted by CharlotteHawk
catalytic converter
Aka: Power robbing device created by auto manufacturers to help break your pocket book when needing to be replaced. I was curious one day and called the dealership to hear that my cat was worth just under CDN$800 on my '01 GA SE 2.4L.
SudburyGrandz
Old 06-10-2005, 08:59 AM
where can i buy a slp system and the magnaflow high-flow cat. And i asked a local shop that installs about them putting on a new cat and they said some thing link the co2 sensor is after the cat so it wont work. Is that true or do they not know what their doing?
Old 06-10-2005, 10:28 AM
Ridenour's Avatar
GranddAmnit
Our 02 Sensors are post-cat - correct. But a high-flow cat still does the job of a stock cat, so it won't throw any engine codes. It still cleans the air properly, it just flows much more freely. As for where to get the slp and cat, here's some links:
SLP:
http://www.pfyc.com/store/merchant.m...ory_Code=GAEXH
High Flow Cat (I couldn't re-find magnaflow, but this one is popular too):
http://www.jegs.com/cgi-bin/ncommerc...34&prmenbr=361
- it's the one at the top. The 2.25" in / out
