Go Back   Automotive Forums Car Chat > Chrysler > Crossfire | Crossfire SRT6 Roadster
Old 06-03-2005, 08:44 AM
2003chevcav 2003chevcav is offline
Crossfire headlight question
Friend just baught an 05 Crossifre. He noticed that the headlights appeared foggy as if condensation were inside the lens. Also noticed that the glass has almost a feathering appearance to it. Is this a design characteristic?
Old 06-05-2005, 03:05 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
No, it means that there is a leak in the headlight that is allowing moisture to get in such as a crack or a hole. This is usually caused by rock chips.
Old 08-09-2005, 04:23 AM
ridefast's Avatar
ridefast ridefast is offline
There is a leak in the headlamp, but it may be caused by some other cause (material failure, poor fitting, etc...). In that case your friend should visit his local Jeep/Chrysler dealer to have it replaced under warranty.
Old 09-17-2005, 03:07 PM
jordan_davis jordan_davis is offline
Re: Crossfire headlight question
That whole Mopar warrenty thing will definatly leave you covered.
Old 01-26-2006, 08:00 PM
VOLATILE VOLATILE is offline
Moisture in the headlamp is considered normal on the crossfire per TSB. Should dissappear after a few minutes w/ hwadlamps on.
Old 08-06-2007, 09:35 PM
MR2spyderB MR2spyderB is offline
My dad's had the same problem...it actually did get it fixed under warrently but they still have that dusty look to them...if it bothers your friend too much just replace them for a couple hundred bucks...but it probably wont really effect your vision at night and its also not that noticable to people outside of the car unless they pay real close attention.
