Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 06-02-2005, 09:26 PM
doityourself doityourself is offline
Any tricks to remove the front motor mount
I have a 93 Continental.
Believe the motor mounts are oil filled with a mechanical internal linkage. I believe the front motor mount has lost all of its oil. When I accelerate from a stop, I see and feel the motor pull up then it hits a stop, probably the linkage at its most extended point.
The Ford service manual says the top bolt can be accessed via a long extension and 18mm swivel socket. All I can see is the exhaust manifold and air conditioning pump.
Do I need to remove any of the accessories before this job is doable?
Also, do you need the engine support tool to raise the motor or can I use a floor jack?
Thanks in advance.
Old 06-03-2005, 01:28 PM
Towncar's Avatar
Towncar Towncar is offline
Sorry, can't help w/1993. I have the 1996 procedures posted here. in PDF format.
Maybe that'll give you some ideas
Some cautions are listed, re: lifting the engine too high.
-Steven
1996 Town Car, Cartier
Old 06-15-2005, 11:09 AM
gbic1 gbic1 is offline
U need a chrome mid deep wobble socket. I use a matco 18 mm i think.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
