Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-02-2005, 07:54 PM
Retard324 Retard324 is offline
Send a message via AIM to Retard324
rough shifting
i just replaced the tranny oil monday, an for the first couple days it shifted so smoothly. but now its shifting roughly. it takes some force to go into every gear and gets caught on something goin from 2nd to 3rd and 4th to 5th. i used 10w-30 from valvoline. is there another some other oil i should use instead or is it something else?
'93 Nissan 240sx
'90 Nissan 240sx - KAE-T? might go NA instead
Old 06-03-2005, 04:21 PM
joellthomas joellthomas is offline
Re: rough shifting
Check a manual, but you normally put transmission oil in a stick shift. 90w
Old 06-03-2005, 05:06 PM
Re: rough shifting
i checked the owners manual and a chilton repair manual and they both said to put engine oil in it. 10w-30 or 10w-40.
'93 Nissan 240sx
Old 06-03-2005, 08:15 PM
hondadude555 hondadude555 is offline
Re: rough shifting
ye dude, I have this problem too. I changed my oil 2 days ago and i thought it would cure the rough shifting problem. I used Honda Manual Transmission Oil. It did not fix the problem. I might bring it to a honda dealership and let them diagnoss whats wrong with it. let me know if you find whats wrong
Old 06-05-2005, 08:56 PM
greenjack greenjack is offline
Re: rough shifting
Preludes have a chronic problem with their tranny syncros after a certain amount of mileage. If it sounds like your trying to shift without the clutch but you have the clutch all the way down, it's your syncro.
Old 06-06-2005, 12:13 AM
92_prelude_si's Avatar
92_prelude_si 92_prelude_si is offline
Re: rough shifting
I have trouble shifting my car into 5th gear after about driving it for a couple of miles. It started doing this a couple of weeks ago. Could that also be the syncroser?
Old 06-06-2005, 03:08 PM
Re: rough shifting
if its grinding, its the shift fork. there was a recall on 92-96 for a mismanufactured shift fork that causes it to grind going into 5th. happens with mine. it should be covered under warrenty.
'93 Nissan 240sx
Old 06-06-2005, 08:12 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: rough shifting
I have the problem too, my friend who's a mechanic said it was my synchros, just from the feel, but we haven't looked into it yet, because it's not too bad. But it seems like greenjack is right, I've heard of this happening a lot lately.
