Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-02-2005, 06:31 PM
Mystikmale Mystikmale is offline
Angry Valve Knocking
i HAVE A H23A1 AND FOR THE PAST 3 MONTHS THE TICKING HAS PROGRESSIVLY HAS GOTTEN LOUDER. MY TIMING IS A LITTLE OFF WOULD THAT CAUSE MY VALVES TO KNOCK LOUDER AND IF SO WHAT SHOULD I DO? AND ALSO MY STERRING WHEEL F**KIN SHAKES LIKE CRAZY. NEW TIRES JUST BALANCED I HAVE NO IDEA WHAT ELSE IT COULD BE?
Old 06-02-2005, 07:55 PM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
get your valves realigned it costs under 80 bucks or if you dont want to pay to have this done buy some Lucas Oil and put it in when changing your oil. It may quite it a small bit. Ur power steering should be fine unless its hard to turn, if it's hard to turn then get a new power steering pump or check your fluid,
Old 06-03-2005, 04:24 AM
bill-the-ba$tard bill-the-ba$tard is offline
Send a message via AIM to bill-the-ba$tard
Re: Valve Knocking
Or.... rather than mask the problem, you could pay the $80 to have your valves adjusted for you.
If you would rather, get out your 10mm socket, a flat head screwdriver, and a socket to turn the crank. Go buy some feeler guages for under $10 and adjust them yourself. I'm not sure what the spec is for your motor, but I'm sure that somebody here does, or you could look it up in a manual. The whole process from popping the hood to shutting it again should take you less than 45 minutes.
