Old 06-02-2005, 07:14 PM
reem22 reem22 is offline
front end
I have a 1997 Park ave, when I go over a bump I hear a noise from the driver side, sounds like somthing is loose. I also hear it when I'm on the gas at about 60-70.
I have replaced both stuts and wheel hub.
Old 06-03-2005, 09:48 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: front end
Did you check the cv boot for tears?
Old 06-14-2005, 02:17 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: front end
Could be CV joint, however going over a bump would not cause a CV joint noise. Usually you will first here CV joint noise when turning tight under power. It will be a louder tick-tick or popping noise. You might check the ball joints or upper strut bearing mount.
