Old 06-02-2005, 05:01 PM
bovic
Guest
Posts: n/a
Check wallet light
After driving for like 5-10 minutes at 50 miles per hour, the check engine soon light comes on, then after I shut the engine and restart, nothing! It'll just eventually come back ON after re-driving the truck.. I can't really ssense anything changing during the ride as the light comes ON, what should I check for? How do I scan the thing? Thanx..
Old 06-02-2005, 07:54 PM
CD Smalley CD Smalley is offline
Re: Check wallet light
Year of van and 8th digit of the VIN please.
My guess is that if you read the codes you will get a code 32 for the EGR valve.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-04-2005, 07:02 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
You should go to autozone and get the codes for free. It'll tell you what the problem is. If the SES light is on you are probably getting below average gas milage.
Old 06-05-2005, 08:16 PM
bovic bovic is offline
Re: Re: Check wallet light
Sorry 1989 Chevrolet Astro .. LT.. Is there a way to get a code? Because its not sticking, every time I shut the engine the light disapears..
Old 06-05-2005, 08:22 PM
No Autozone here bud, Montreal.. I just wonder if I could get the codes with this:
http://www.canadiantire.ca/assortmen...=1118020754846
'Cause anyway they'll charge me like $50 to get an estimate and I'm a verry accurate mecanic and electrician.. I'll fix it myself.. Like CD smili said its possibly the EGR stuff ports that needs cleaning, is it a big job on these 4.3l?
Old 06-06-2005, 05:41 AM
How do I read my computer codes?
NOTE - This is a work in progress!!!!!
Tools needed:
Your car keys
A paper clip or a three(3) inch long piece of safety wire.
First thing you need to do is find your Assembly Line Diagnostic Link or ALDL. It s small black plastic piece about two (2) inches wide by one half(0.5) inch tall. It has twelve (12) female connector inside. The ALDL can be found under the driver's side of the dash, usually attached with two (2) screws to the bottom side of the dash.
The ALDL :
Now that you've found the ALDL, bend the paper clip or the piece of wire into a U shape. With the ignition in the OFF position. Insert one end into the A slot and one into the B slot. Now turn the the ignition to the ON position. DO NOT start the car. As the ECM begins it's self-test if will begin to flash the SES light to provide the codes. The flashes will appear like this : *flash* short pause *flash* *flash* long pause then repeat. Each code will be displayed three(3) times. Code 12 will be repeated to indicate the end of the set codes. If you all you get is Code 12 then you have no codes set in your ECM.
An example of a sequence for a common code :
*flash* short pause *flash* *flash* long pause = Code 12, Testing the ECM
*flash* *flash* *flash* short pause *flash* *flash* long pause = Code 32, EGR
Clearing the codes is really quite easy. Unhook your battery for about 2-3 minutes and then hook it back up.
These codes cover the OBD-I computers only.....
All currently listed codes are from the 1989 B-car Service Manual. Why? Because that's what I have.
CODE AND CIRCUIT POSSIBLE CAUSE
CODE 12 = System check
Indicates that the ECM is functioning.
CODE 12 = No Engine Speed Reference - VIN 'Y' CARB
Indicates an open or ground in the distributor reference circuit.
CODE 13 = OPEN Oxygen Sensor (O2)
Indicates that the oxygen sensor circuit circuit or sensor was open for one minute while off idle.
CODE 14 = Coolant Sensor (CTS)
Sets if the sensor or signal line are grounded for 3 seconds. HIGH Temperature indication.
CODE 15 = Coolant Sensor (CTS)
Sets if the sensor wires or connections are open for 3 seconds. LOW Temperature indication.
CODE 21 = Throttle Position Sensor (TPS)
TPS voltage of more than 2.5 volts for 3 seconds at an engine speed less than 1200 rpm. HIGH Voltage Signal.
CODE 22 = Throttle Position Sensor (TPS)
A shorted to ground or open signal circuit will set code in 3 seconds. LOW Voltage Signal.
CODE 23 = Manifold Air Temperature Sensor (MAT)
Sets if the sensor wires or connections are open for 3 seconds or Intake Air Temperature (IAT) LOW Temperature indication.
CODE 24 = Vehicle Speed Sensor (VSS)
No vehicle speed present during road/load deceleration. NO Vehicle Speed Indication.
CODE 25 = Manifold Air Temperature Sensor (MAT)
Sets if the sensor or signal line are grounded for 3 seconds. Or Intake Air Temperature (IAT)
CODE 32 = Exhaust Gas Recirculation (EGR)
OR Vacuum switch shorted to ground on start up. Switch not closed after the ECM has commanded EGR for a specified period of time OR EGR solenoid circuit open for a specified period of time.
CODE 33 = Manifold Absolute Pressure (MAP)
MAP sensor output too high for 5 seconds or an open circuit. LOW Vacuum.
CODE 34 = Manifold Absolute Pressure (MAP)
Low or no output from sensor with engine running. HIGH Vacuum.
CODE 35 = Idle Air Control (IAC)
IAC error.
CODE 42 = Electronic Spark Timing (EST)
ECM has seen an open or grounded EST or Bypass circuit.
CODE 43 = Electronic Spark Control (ESC)
Signal to the ECM has remained low for too long or the system has failed a functional check.
CODE 44 = LEAN Exhaust Indication
If voltage to oxygen sensor remains BELOW .2v for more than 20 seconds code is set.
CODE 45 = RICH Exhaust Indication
If voltage to oxygen sensor remains ABOVE .7v for more than 1 minute code is set.
CODE 51 = PROM - Faulty MEM-CAL or ECM.
CODE 52 = Faulty or missing CAL-PACK.
CODE 53 = System overvoltage
Indication of a faulty alternator or regulator. Camaro/Firebird uses a Code 53 for Vehicle Anti-Theft System (VATS).
CODE 54 = Low Voltage To Fuel Pump
Sets when the fuel pump voltage is less than 2 volts when reference pulses are being received.
CODE 55 = Faulty ECM
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 06-06-2005, 05:12 PM
Wow, that's quite precise CD Smalley and i'm off work tomorrow, I'll check that and let you all know..
Old 06-06-2005, 10:12 PM
Well I've answered that question before...several times.
Does it show? I have that stuff in a file that I keep...as Foghorn Leghorn used say "for just such an emergency.".
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 06-07-2005, 06:48 PM
No time today.. Thursday's the day..
