Old 06-02-2005, 05:36 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Oh god no...No no no!
Just got back from driving around. Not beating up on it or anything. So i go to make a quick left into Autozone, push the clutch in and the rpm's drop off to almost nothing. Car almost stalled. Then right after that, my clutch felt spongy. NNNOOOOOOOOO! This damn motor only has a little over 30,000 miles on it! Maybe it was just a fluke, who knows. Didn't give me a bit of trouble after that. But you all know what these two signs are. Crankwalk Mitsu said they had put all upgrade parts in the motor the first time it CW'd and i should never get it again. The claimed Mitsu had fixed the problem and when they ordered everything, they were the revised parts. I really hope my crank isn't floppin around in there. It isn't time for it to go for a walk damnit!
Old 06-02-2005, 06:01 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Oh god no...No no no!
Was it under warranty? Did it come with a warranty?
....It has been a LONG time...I want to move to FL or Japan.....
Old 06-02-2005, 09:07 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
WTF! Dam DSM's Hopefully it was just a fluke.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 06-02-2005, 09:40 PM
it HAD a warranty of 12,000miles/12months.....and i just took it out again to show my friend what it was doing and it started doing it again....so we started going back to my house and my temp gauge was spiked at well over 250F! as soon as i pulled into my neighborhood i turned the ignition to off and coasted into the garage, my motor was smoking! popped the hood and a big cloud of smoke filled the bay. fresh coolant on the ground. WTF! i checked the thermostat. it must be opening cause the upper radiator hose was hot, but when i tried turning the heat on, it was cold. what could this be? water pump? head gasket? please help asap! thanks guys.
Old 06-02-2005, 09:46 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Sounds like a headgasket to me. That is what happened when I blew mine. Was it white?? That is my bet.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 06-03-2005, 12:25 AM
found the problem...it blew a hose off the back of the thermostat...so i put it back on and filled up the fluid. seems to be running at normal operating temp now good thing we noticed the temp right away and didn't drive too long with a temp that high. as for the rpm drop on left turns....ahhh i'm hoping it's not CW.
Old 06-03-2005, 01:59 AM
joemathews's Avatar
joemathews joemathews is offline
Crankwalk is just an excuse to build your 6 bolt and put in a 60 trim
But seriously, don't worry about it until it happens, because there is nothing you can do to stop it!
1996 Eagle Talon
Old 06-03-2005, 02:27 AM
kjewer1 kjewer1 is offline
AF - Advisor
I was going to suggest low coolant level from a leak. When the level drops a little bit, the heat is the first thing to go.
I would pry the pulley away from the framerail (toward the motor) and have a friend hit the clutch. It is perfectly normal to be able to see it move, but it should be a small amount. .010 inches is around the service limit. If its like a 16th or an 8th of an inch or something, might as well start planning to fix it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-03-2005, 12:46 PM
a little update....i raised the idle just a tad because it was a little low and the vac was like 14....now the vac is around 16 at idle, idle is approx 800. (would having the EGR solenoid nipple broke cause a low vac like this?). anyway i took her for a spin. temp was just under 210, and it didn't drop rpms once on any left/right turn. hopefully it was just a fluke, but i'm gonna try what you said kevin. hopefully it doesn't move out of that range.
Old 06-03-2005, 05:36 PM
Whathits14 Whathits14 is offline
Re: Re: Oh god no...No no no!
mmmm damn good excuse too....
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
