Go Back   Automotive Forums Car Chat > Honda > S2000
Old 06-02-2005, 02:19 PM
Talibangunner925's Avatar
Talibangunner925 Talibangunner925 is offline
2.0 or 2.2??
I was looking fora new car and i ran across the s2000 hoe ever i was wonder waht to the the 2003- 2.0 or the 2004+ 2.2 i defnatly want to mod it. How ever if parts are coming out for the 2.2 then i would rahter have that. also with the new engine are there any other diffrences??
Old 06-02-2005, 02:25 PM
want a supra want a supra is offline
Re: 2.0 or 2.2??
I say go for the 2.2... You can never go wrong with a bigger motor .
Originally Posted by GForce957
Those who eat the Breakfast of Champions wear velcro sneakers
Old 06-02-2005, 09:54 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
The F20C and the F22C have the same horsepower. The F22C has more torque. The F22C also has a lower redline.
There are plenty of parts coming out of the F22C, and a majority of the parts are interchangable between the F20C and the F22C.
Old 06-03-2005, 01:35 AM
V T E C H's Avatar
V T E C H V T E C H is offline
Re: 2.0 or 2.2??
I belive they changed from the 2.0 L to the 2.2 L was due to Honda wanting to make the car appel to a wider audience, and thus lowering the red line. Other then that i belive they are pretty much the same. There is a great article about the 2004 S2000 in Sport Compact car, when the 04 first came out.
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 06-03-2005, 01:49 AM
SiGNAL748's Avatar
Yeah, they upped it to 2.2 to add more torque, and lowering the redline to make the car more "daily driveable". The original motor, you had to rev the piss out of it to go anywhere.
Old 06-03-2005, 01:08 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: 2.0 or 2.2??
it felt like a b16 daily driven but once it was in vtec was alive.
Old 10-13-2005, 10:22 PM
a5678's Avatar
a5678 a5678 is offline
So, is there that big a difference between the two engines? Performance wise, is the 2.2 liter engine better? I would prefer the lower redline to get power earlier, but I don't know if it's worth buying a more expensive post 2003 S2000, or just getting an older one with the 2.0 liter engine. I am thinking of buying an S2000 in a few years. I am definitely not buying a new one; I want to buy a used one because of the lower price.
Old 10-15-2005, 12:48 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
F20c (1997cc) - Bore x Stroke: 3.42 x 3.30 240 hp @ 8300 and 153 tq @ 7500 Rev limit: 9000 C/R: 11.0:1
F22c (2157cc) - Bore x Stroke: 3.43 x 3.57 240 hp @ 7700 and 162 tq @ 6500 Rev limit: 8500 C/R: 11.1:1
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 02-14-2006, 04:34 AM
matt_hylton matt_hylton is offline
Re: 2.0 or 2.2??
get the 2.0 and buy the 2.2 borkit for it, you'll get the higher redline(which i consider a good thing), and the tourqe, the 04+ also had some differences in the tranny, i know the gearing is shorter in the later, but you can buy new gears too.
And if you go with a 00 or 01, you'll save enough money do to the mods.
Old 02-14-2006, 04:30 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: 2.0 or 2.2??
old thread
Old 02-24-2006, 10:15 PM
Guido s2k's Avatar
Guido s2k Guido s2k is offline
Re: 2.0 or 2.2??
That's probably not a good idea. The reason they lowered the redline was because of the increased stress at higher speeds. I've read online that you can only safely run an F22C engine at 8,500 RPM, anything over that will eventual cause damage. There are alot of tuners that run it at 9,000, but they do not intend to keep these engines for the long term.
If you're short on cash then go for the 2.0L engine. It has the same amount of power, but because it has less torque you need to rev it higher to reach it. They also changed the gearbox for '04+, shortening the first 4 gears, and lengthening 5th and 6th. Either way you go, you can't go wrong with an S2000
Old 03-06-2007, 12:05 PM
Jet Fetish Jet Fetish is offline
Re: 2.0 or 2.2??
the ap1 has 240hp the ap2 has 237hp
